Double side tape frustration
Forum topic by mchuray posted 07-25-2011 03:44 AM 1332 views 0 times favorited 4 replies Add to Favorites Watch
View mchuray's profile
mchuray
81 posts in 2867 days
07-25-2011 03:44 AM
Ok I got the tape and made the patterns etc.etc. Getting the covering off the tape is a real PITA. Spent all afternoon fighting the tape. Maybe its because the tape has been in the hot shop. I don’t know. Sure looks easy when they do it on TV. Finally got two patterns in place. Only 4 more to go.
Mark
View Grandpa's profile
Grandpa
3259 posts in 2544 days
#1 posted 07-25-2011 05:35 AM
try storing the tape in the veggie crisper of the frig. Talk to the wife first though
View treeman's profile
treeman
208 posts in 3318 days
#2 posted 07-25-2011 11:50 AM
I use double sided tape a lot and fought the same frustration until I found a solution that works for me. To remove the covering after I have stuck the tape to one piece, I take the point of an X-acto knife and insert it at an angle about 1/4” from a corner of the tape. Insert the knife just enough to get under the backing and lift. You will now have a loose corner you can grab.
View bubinga's profile
bubinga
861 posts in 2536 days
#3 posted 07-25-2011 12:19 PM
I use a knife also for Double side tape
Are you using it to stick on templates ,or paper patterns ?
-- E J ------- Always Keep a Firm Grip on Your Tool
mchuray
#4 posted 07-27-2011 04:25 AM
Thanks all for the suggestions. I found that if I make a light cut with an X-acto knife at the corner and scrape at the tape I can get an edge up that I can then pull the covering off. I did put the tape in the fridge and seems to help.
Mark
