Has anybody made Chris Swarz's bowsaw chair? Question.
Forum topic by Jeremymcon posted 08-20-2018 07:59 PM 668 views 0 times favorited 1 reply Add to Favorites Watch
View Jeremymcon's profile
Jeremymcon
306 posts in 919 days
08-20-2018 07:59 PM
Ok. I decided to make this chair with some 6/4 white oak that I’ve had around forever. However, it calls for 2.5” thick uprights. Maybe it’s just because I’m using white oak, but the uprights seem a lot thicker and heavier that I’m thinking they need to be. I feel like they look heavier than they do in the picture in article too.
Also, the stretcher is in a mortise that’s only 1/8” deep on each side?
Has anybody made this chair? Did you follow the plans as written? Did it work?
1 reply so far
View ralbuck's profile
ralbuck
5541 posts in 2505 days
#1 posted 08-20-2018 08:37 PM
I have NOT made that chair.
I do know from past mistakes; the plans are not GOSPEL on anything. They are a place to start from.
If you think that you know a better way—-TRY IT! Maybe on a cheap piece pf wood first to see, then the lossis only time of it does not work out.
Good Luck!
-- Wood rescue is good for the environment and me! just rjR
