Help! My vintage lathe motor starts smoking and leaking oil after 15-20 sec of use.
« back to Woodturning forum
Forum topic by Rus2248 posted 08-19-2018 09:59 PM 3019 views 0 times favorited 19 replies Add to Favorites Watch
View Rus2248's profile
Rus2248
21 posts in 159 days
08-19-2018 09:59 PM
Topic tags/keywords: lathe turning refurbishing repair motor
I recently aquired a vintage sears craftsman wood lathe and was looking forward to getting started turning wood. One thing after another, I finally got it all set to run. Understand, I have no mechanical experience and I am self/youtube taught. When I run my lathe, after about 15 seconds, the Craftsman motor starts smoking and leaking oil from the top cover (picture below). What can I do to prevent this?
-- Rusty, Wichita, Kansas
19 replies so far
View lew's profile
lew
12498 posts in 3992 days
#1 posted 08-19-2018 10:04 PM
Sounds like a bad capacitor. Unplug the lathe take off the cover and remove the capacitor. Any motor repair shop should have a replacement
View robscastle's profile
robscastle
5631 posts in 2441 days
#2 posted 08-19-2018 10:35 PM
A polychlorinated biphenyl (PCB) is an organic chlorine compound … Some PCBs share a structural similarity and toxic mode of action with dioxins. .... Examples of closed applications include coolants and insulating fluids (transformer oil) for transformers and motor starter capacitors, also may be found used in old fluorescent lights.
-- Regards Rob
View GR8HUNTER's profile
GR8HUNTER
5377 posts in 949 days
#3 posted 08-19-2018 10:46 PM
for sure a bad cap. make sure you get same specs. for your replacement :<))
Rus2248
#4 posted 08-20-2018 12:16 AM
It would appear that you are speaking some form of english; however, I am unfamiliar with this dialect.
- robscastle
Rus2248
#5 posted 08-20-2018 12:18 AM
Thank you guys for the “Dummies Guide” breakdown. I will try this and see what happens. Unfortunately, I don’t know of any machine shops nearby, so I’ll probably be ordering it online. Thanks again!
GR8HUNTER
#6 posted 08-20-2018 12:33 AM
when you take the cover off it will be bulging out just make sure the specifications are the same :<))
View HerbC's profile
HerbC
1792 posts in 3096 days
#7 posted 08-20-2018 03:22 AM
You don’t have to know any of the local shops to do business with them. Googling “electric motor repair shop Wichita, Kansas” will produce pages of listings. A few quick phone calls will put you in touch with someone who will be able to supply your needed part quickly and cheaply…
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#8 posted 08-20-2018 05:16 AM
Or grainger or A/C supply place of that doesn’t work out.
View JohnChung's profile
JohnChung
416 posts in 2311 days
#9 posted 08-21-2018 03:39 PM
just change the cap
View Fresch's profile
Fresch
369 posts in 2158 days
#10 posted 08-22-2018 01:58 PM
PCB, is a cancer causer, wash your hands before licking them. Not a concern.
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1967 days
#11 posted 08-23-2018 01:12 AM
- Fresch
There are only one or two things that get the honor of a finger lick, and working on an electric motor wouldn’t be one of them…........ Jerry (in Tucson
Rus2248
#12 posted 10-20-2018 06:25 PM
So… here it is, 2 months later, and I finally was able to work on the motor. I got a replacement capacitor and installed it yesterday, and she was running beautifully, for about 5 minutes. Then she started smoking again with oil coming from the capacitor housing. This time I did some serious investigating. I think I found the issue…
With some elbow grease, and most of my night, I got her all cleaned up. Still a little apprehensive due to my lack of expertise on this subject. Do you guys think it’ll work?
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#13 posted 10-20-2018 06:32 PM
Should be fine… there isn’t much to an induction motor and they are relatively easy to work on. Also, it appears your motor has sleeve bearings instead of ball bearings… Make sure you keep them well lubricated (any good ~20W non-detergent oil will work).
Rus2248
#14 posted 10-20-2018 10:18 PM
Well, that’s the end of that… i give up
MrUnix
#15 posted 10-20-2018 10:47 PM
You did replace the capacitor didn’t you?
PS: I’ve never seen one fail like that!
