drying time for oil based stain
Forum topic by dbw posted 08-19-2018 09:13 PM 359 views 0 times favorited 4 replies Add to Favorites Watch
View dbw's profile
dbw
229 posts in 1875 days
08-19-2018 09:13 PM
Topic tags/keywords: stain drying time temp humidity
The can of GF warm cherry stain states a ideal drying conditions are 70F and 70% RH. If the temp is 86F and the RH is 37% is the drying time increased or decreased?
-- measure 3 times, cut once
View therealSteveN's profile
therealSteveN
1903 posts in 813 days
#1 posted 08-20-2018 01:00 AM
Warmth will usually increase the speed finishes dry at, and humidity over 70% will start to hamper drying because there is added moisture in the air. So in your case I’m envious of your 37% Rh.
The age of the finish will also change the time to dry, older finishes get slower to dry, but you can’t know until you can touch it to see how it is coming along.
I always say if in doubt, leave it alone, nothing can queer a project like a finish that isn’t ready.
-- Think safe, be safe
View OSU55's profile
OSU55
2029 posts in 2228 days
#2 posted 08-20-2018 07:28 PM
Decreased significantly. Best to do a rub check with a white cloth to see if it is dry.
View dbw's profile
dbw
#3 posted 08-20-2018 11:06 PM
Should a rub test result in zero stain on the cloth?
OSU55
#4 posted 08-21-2018 12:11 PM
Zero oil yes. Some of the pigment may rub off. Dont have to rub hard.
