What is the best way to change table saw blade?
Forum topic by tool_junkie posted 07-24-2011 03:17 AM 10364 views 0 times favorited 17 replies Add to Favorites Watch
View tool_junkie's profile
tool_junkie
322 posts in 2498 days
07-24-2011 03:17 AM
Hello Everyone,
This might just sound out right stupid of me to ask, but I am gonna ask anyways; what is the best way to change the blade on a table saw? I have been using the method outlined in my craftsman table saw manual which call out for using a piece of wood to secure the blade while loosening and tightening the arbor nut, but I never liked this idea. I recently bought the Milescraft “blade changer” and gave it a try for the first time today. (http://www.milescraft.com/product/3401.html)
The blade changer failed miserably! My blade just ate the plastcis bumps that are supposed to stop the blade from rotating while you loosen the arbor nut! It was a frustrating experience.
I need to find a better way to change the blade! Please share if you know of an easy way.
Thanks!
17 replies so far
View Dan's profile
Dan
3630 posts in 2849 days
#1 posted 07-24-2011 03:22 AM
I use my wooden push stick to stop the blade when changing it. The nut only needs to be tightened a bit since its reverse thread.
-- Dan - "Collector of Hand Planes"
View Grandpa's profile
Grandpa
3259 posts in 2644 days
#2 posted 07-24-2011 03:26 AM
I have always (because I was taught this way I suppose) used a block of wood, my push stick or whatever and a wrench. I have an old Craftsman saw that came with 2 wrenches. It has a hex or flats behind the blade for one wrench. I was taught to use a wood block. Like mentioned above it doesn’t take much tightening because it should self tighten. Just snug it up good and saw!
16274 posts in 4187 days
#3 posted 07-24-2011 03:51 AM
I don’t know if this is kosher, but it’s how I do it:
My Ridgid TS3660 has two wrenches. One fits on the inside of the blade, and you can gently rotate the shaft until that wrench is resting snugly against front edge the throat opening. Then you take the second wrench, put it on the outside of the blade, and pull toward you till the nut loosens. Reverse the process to reinstall.
Grandpa
#4 posted 07-24-2011 03:54 AM
That is the way this old Craftsman saw works but most saws have just the nut on the arbor and you use one wrench and the wood block holds the blade.
View knotscott's profile
knotscott
7983 posts in 3344 days
#5 posted 07-24-2011 04:22 AM
I also use my pushstick or whatever scrap I have lying around. I also never tighten the nut very much when I reinstall the blade…just snug it a little.
View lew's profile
lew
12019 posts in 3724 days
#6 posted 07-24-2011 04:23 AM
Wooden push stick or scrap piece of wood.
View rance's profile
rance
4255 posts in 3129 days
#7 posted 07-24-2011 04:51 AM
Two wrenches. What method does your manual suggest?
27250 posts in 3791 days
#8 posted 07-24-2011 10:20 PM
When I had my Craftsman saw using a block of wood to secure the blade was the technique that I would use to loosen the blade. I tried the Benchdog version of your Milescraft product and did not like it either. Using a block of wood was much easier since there are always some lying around.
View Lee Barker's profile
Lee Barker
2170 posts in 2819 days
#9 posted 07-24-2011 11:03 PM
I made a little paddle shaped thngy out of 4/4 wood; shaped a handle on it and it lives in the drawer with the arbor wrench. My saw (long story) didn’t come with a wrench so I bought a stock one and sawed off the end that didn’t apply and dipped it in that Dip’n’Grip stuff.
+1 on the just snug the nut concept.
Kindly,
View pintodeluxe's profile
pintodeluxe
5624 posts in 2782 days
#10 posted 07-24-2011 11:06 PM
Bench Dog Blade Loc. Put it over your blade and the friction keeps it from turning while loosening the nut. Much safer / easier than the old wooden stick method.
View Tedstor's profile
Tedstor
1643 posts in 2601 days
#11 posted 07-24-2011 11:11 PM
Whats not to like about the “wood” method?
View DamnYankee's profile
DamnYankee
3301 posts in 2531 days
#12 posted 07-24-2011 11:27 PM
I just use the two wrenches that came with my table. One holds the arbor in place while the other loosens/removes the nut. Kinda like on my router.
-- Shameless - Winner of two Stumpy Nubs Awards
View ShaneA's profile
ShaneA
6912 posts in 2567 days
#13 posted 07-24-2011 11:47 PM
Two wrenches for me, seems to work well. Never felt the need to try any other way.
View JimF's profile
JimF
144 posts in 3262 days
#14 posted 07-25-2011 03:09 AM
I have a couple of left hand leather gloves (the right ones always wear out first). I just grip the blade with the gloved left hand and the wrench in the ungloved right hand. I feel better about recycling a glove rather than pitching it when the right wears out.
Just thought. does gthis mean my blades are not sharp enough since they don’t cut the leather?
-- Insert clever tag line here
View Dusty56's profile
Dusty56
11819 posts in 3657 days
#15 posted 07-25-2011 04:42 AM
Start off by unplugging your saw…....block of wood and a wrench and you’re done. I’ve also used the “glove” method…...No need to overtighten the nut : )
