Grain direction for base trim around square column
Forum topic by Mark Shultz posted 08-19-2018 08:10 PM 355 views 0 times favorited 7 replies Add to Favorites Watch
View Mark Shultz's profile
Mark Shultz
109 posts in 2511 days
08-19-2018 08:10 PM
I have several vertical 12” x 12” cedar columns to which I need to add the base molding. This is for an exterior application. Normal inside trim runs horizontal. What direction should the grain be in this application? I think if horizontal, then the cross grain expansion / contraction might be an issue. And if vertical (i would glue up boards to achieve width) then the top of the base would have end grain eager to absorb rain water.
Thoughts?
7 replies so far
View Rich's profile
Rich
3548 posts in 710 days
#1 posted 08-19-2018 09:24 PM
If you go with the grain vertical, then seasonally you are going to see gaps in the corners (I assume mitered).
Mark Shultz
#2 posted 08-19-2018 11:23 PM
I was thinking the opposite. Vertical column + vertical base = no difference in expansion / contraction
View Rich's profile
Rich
#3 posted 08-20-2018 12:48 AM
- Mark Shultz
I assumed the columns were structural and made of heavier stock that would move less. If it’s decorative and both are the same thickness, then you’re probably right.
View HTown's profile
HTown
114 posts in 1307 days
#4 posted 08-20-2018 02:59 AM
I faced the same question, here was my solution. I ran the trim horizontally, against the grain of the column. I mitered the trim oversized by 1/8” and then glued two of the four corners and added some brads for extra strength. After that, I finished installing it around the column and glued the last trim piece in place. At this pint it was loose around the column so I put some soft foam to center the trim piece and caulked it to keep water out. So far it has held up for two years with no signs of the joints opening.
View John Smith's profile
John Smith
1313 posts in 283 days
#5 posted 08-20-2018 11:30 AM
make the collar 1/8-1/4” larger than the column and put some soft foam to center
the trim piece and caulk it to keep water out.
- HTown
X2 – - – with Elastomeric Caulk
[Elastomeric Sealant – BORG/BLU]
DAP EXTREME STRETCH is a premium urethanized sealant ideal for sealing a wide variety
of interior and exterior surfaces. It is specially formulated to stretch over 600%
ensuring the seal does not crack or lose adhesion with age.
(or any Name Brand).
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View rwe2156's profile
rwe2156
3073 posts in 1601 days
#6 posted 08-20-2018 01:49 PM
- Mark Shultz
Yes, in theory this is true. In reality, the base is likely to move more than the column simply because its a smaller mass of wood & more subject to humidity. Plus, you’ve got the top edge endgrain exposed to the elements.
You’re going to have an issue with movement in a 12” wide board. Are they going outside? Are they 4/4 boards applied over a post? If so, how are you going to address the corners? In a post that wide you can cover the corners with battens or corner moulding. Mitering will not work.
I would apply the base horizontally and use nails. This will allow for movement. DO NOT glue it.
Mark Shultz
#7 posted 08-24-2018 08:50 PM
It’s is definitely outside, and the 12×12 is also decorative /non structural, so hopefully expansion/contraction is the same (but will be large). It will also not be finished, so the caulk idea is out.
Maybe I should put it vertical, and out a cap on it that is horizontal.
