Suggestions for Stabilizing Butcher Block
Forum topic by anthonyhm posted 08-19-2018 05:19 PM 378 views 0 times favorited 8 replies Add to Favorites Watch
View anthonyhm's profile
anthonyhm
5 posts in 167 days
08-19-2018 05:19 PM
Hi there, I’m putting together a large butcher block table top and matching coffee table for a client and unfortunately it cracked when I was cleaning it up. Any suggestions on how to stabilize these?
8 replies so far
View John Smith's profile
John Smith
1551 posts in 400 days
#1 posted 08-19-2018 06:22 PM
what kind of wood is that ? (looks like Southern Yellow Pine).
and – while “cleaning it up” what were you doing to it ??
-- I started out with nothing in life ~ and still have most of it left.
anthonyhm
5 posts in 167 days
#2 posted 08-19-2018 06:24 PM
It’s Douglas fir actually and it didn’t actually crack while I was working on it I should say, I noticed it when I pulled it out to work on it.
A little background, it’s a slab that’s 35” x 72” and about 2 23/32” thick with a taper to about 1 15/16”. I’m planning the thick end down to match the thinner thickness right now.
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#3 posted 08-19-2018 07:16 PM
Saw it off and replace.
-- Bondo Gaposis
anthonyhm
5 posts in 167 days
#4 posted 08-19-2018 09:36 PM
Well that’s an option, I was hoping to avoid that, thus the reach out for suggestions.
View Rich's profile
Rich
4002 posts in 827 days
#5 posted 08-19-2018 10:14 PM
If it were me, I’d toss it and build something out of real hardwood. It looks like scrap glued together. I can’t imagine what “client” would be paying for that.
anthonyhm
5 posts in 167 days
#6 posted 08-19-2018 11:23 PM
If it were me, I d toss it and build something out of real hardwood. It looks like scrap glued together. I can t imagine what “client” would be paying for that.
- Rich
Thanks for being constructive Rich. It’s helpful advice like this that makes everyone love these forums.
Thanks for the suggestions guys, I’ll likely just saw it off like Bondo mentioned.
View CaptainKlutz's profile
CaptainKlutz
699 posts in 1732 days
#7 posted 08-19-2018 11:30 PM
Not a surprise?
That crack near glue line was an accident waiting to happen! Is due the huge difference in grain density of the two pieces of wood. Cut off the fine grain wood, and glue another piece on with similar large grain density/direction if you need the width.
If you have any other areas of top with similar large changes in grain density, more cracks will probably happen during normal temp/humidity changes.
+1 – use a hardwood for table top.
Douglas Fir is softwood and makes a lousy butcher block surface as it dents easily. Remember, Wood is cheap compared to expensive customer repairs/returns.
anthonyhm
5 posts in 167 days
#8 posted 08-19-2018 11:49 PM
Not a surprise?
- CaptainKlutz
Thanks Klutz, I appreciate the explanation and the suggestion. I can’t take responsibility for the original glue-up. This is actually an old piece of the Santa Monica College auditorium sound reflector that was around the stage that they wanted turned into a piece for the story more than anything.
I normally agree with your hardwood suggestion as well, although the dense grain in fir does make it tougher than some other wood which is why I’m interested with working with it here. In any case, I appreciate the response. Thanks.
