HVLP Tip size for Primer
Forum topic by Joel_B posted 08-19-2018 12:21 AM 265 views 0 times favorited 3 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
347 posts in 1500 days
08-19-2018 12:21 AM
Just got my Fuji Mini Mite 3. First project is painting kitchen cabinets.
I have a little HVLP experience with a cheap Rockler gun.
I am learning to spray WB Primer from Target Coatings. Thinned to about 30 seconds.
I was getting major orange peel with 1.8 mm tip. I read some things that said to use a smaller tip although 1.8 seems to be recommended for primer.
So I changed to 1.3 mm and it seems to be atomizing much better, also turning down the paint volume helped.
I know it takes some trial and error to get the right settings.
Thanks for any advise.
Realized taking the gun apart to clean it I think used the 1.3 mm needle with the 1.8 mm nozzle.
Going to start fresh tomorrow and start with 1.8 mm again, then switch to 1.3 mm and then decide.
-- Joel, Encinitas, CA
3 replies so far
View AlaskaGuy's profile
AlaskaGuy
4364 posts in 2428 days
#1 posted 08-19-2018 12:55 AM
Joel_B
#2 posted 08-19-2018 03:58 AM
Looks like some good info – Thanks
Joel_B
#3 posted 08-21-2018 12:27 AM
Ended up starting with 1.3 mm tip and it seemed good so didn’t try the 1.8 mm again.
Finish came out really well. I think there were some spots I put the primer on too light and it came out very slightly grainy. After sanding it will be fine. Really like the Mini Mite 3, its quieter than I expected.
