bottom plate of basement partition wall
« back to Coffee Lounge forum
Forum topic by rjherald posted 08-18-2018 08:16 PM 646 views 0 times favorited 8 replies Add to Favorites Watch
View rjherald's profile
rjherald
18 posts in 426 days
08-18-2018 08:16 PM
Topic tags/keywords: question
i know this is not exactly woodworking but i was wondering if anyone had seen this before. Part of our basement is unfinished but framed and the bottom plate seems to be a regular 2×4 sitting on a piece of some sort of wood white in color and about ½” thick. the bottom plate does not look like pressure treated lumber. Has anyone seen or heard of this? I thought code was always PT lumber when in contact with concrete. thanks
rjherald
-- rjherald, indianapolis
8 replies so far
View John Smith's profile (online now)
John Smith
1318 posts in 284 days
#1 posted 08-18-2018 08:43 PM
this is one of those times where photos would really help with the accurate feedback.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View CaptainKlutz's profile
CaptainKlutz
461 posts in 1616 days
#2 posted 08-18-2018 08:56 PM
White wood? Did you check if it was foam insulation?
Many building codes allow use of foam sill gasket under frame wall on concrete, basically to reduce moisture uptake in wood. 1/2 inch thick seems thicker than off-the-shelf white/pink sill gasket I used in past, as it is more like 1/4” thick uncompressed. Pictures are only way to really help.
rjherald
#3 posted 08-18-2018 11:01 PM
thanks for the reply here is the picture
rjherald
John Smith
#4 posted 08-19-2018 02:09 AM
how old is the building ?
without digging a piece of it out with a screwdriver and having it
analyzed at the local box store, there is no way to really tell what it is from here.
View Firewood's profile
Firewood
442 posts in 1755 days
#5 posted 08-19-2018 02:43 AM
If I had to make a guess, I’d say it’s a PVC board. But that is only my unprofessional guess. It would provide the barrier needed to prevent water wicking into the 2×4, but why go through that rather than just use PT lumber?
-- Mike - Waukesha, WI
rjherald
#6 posted 08-19-2018 03:32 AM
i thought pvc my self. the house is only 8 years old and i was just curious as to why the builders did it this way. thanks for the help
rjherald
View Woodknack's profile
Woodknack
12341 posts in 2501 days
#7 posted 08-19-2018 05:23 AM
You could sweep a few years of crud and cobwebs away and poke it with a screwdriver to see if it’s foam, dentable like wood, or hard like pvc. Hard to identify something by color alone.
View Fresch's profile
Fresch
305 posts in 2042 days
#8 posted 08-19-2018 10:47 AM
And your wood has a green tint in your picture on my screen so could be pt.
