Shop Machine Mobility
Forum topic by CartersWhittling posted 07-23-2011 04:07 AM 5910 views 0 times favorited 14 replies Add to Favorites Watch
View CartersWhittling's profile
CartersWhittling
453 posts in 2643 days
07-23-2011 04:07 AM
Topic tags/keywords: question
Hello. I have now aquired most of the major wood working machines I will get, other than a jointer, and they all have temporary bases now. I have been looking around to find different ways to make my machines (bandsaw, benchtop planer, router table, bench top table saw) mobile because I will often need to move around my machines for the space or to accomodate long timbers. Any ideas for shop machine mobility and bases for planers, bandsaws, and router tables ?
-- And whatsoever ye do, do it heartily, as to the Lord... Colossians 3:23
14 replies so far
View WayneC's profile
WayneC
13753 posts in 4066 days
#1 posted 07-23-2011 04:10 AM
It would depend on the shape of the stand. I’m using the ones that use wood stock between metal wheels on my bandsaw and planer. My router table is not on wheels.
View Loren's profile
10278 posts in 3617 days
#2 posted 07-23-2011 05:04 AM
I mobilize machines as I get around to it. I have a narrow pallet jack I
use for my table saw. If I didn’t have wheels already on most
of the other stuff, I’d probably use the pallet jack for them too.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3449 days
#3 posted 07-23-2011 05:53 AM
I have pretty much all of my machines on mobile bases. I have some after-market bases. I also have some of the bases that you buy the wheels and corners and use wooden stringers, and I also have some Powermatic bases since most of my equipment is Powermatic. I find the ones with the wooden stringers seem to work well. I do have some issues with the after-market bases…especially the one on my mortise machine…its not very strong and tends to sag a bit although the machine weight is about 350 lbs. I find if I put a piece of 3/4 plywood in the base then set the machine on it it tends to work better. The Powermatic bases are great but expensive.
-- Wayne - Plymouth MN
View TheWoodNerd's profile
TheWoodNerd
291 posts in 3160 days
#4 posted 07-23-2011 08:21 AM
I’ve also been using pallet jacks, in my case a “mini” version. http://www.thewoodnerd.com/workshop/mobileBases.html
In my experience, you want any mobile base to put the machine directly on the floor during use. Whether it’s a pallet platform, a frame that drops onto the floor, retractable wheels, or screw-down stabilizers, avoid having the machine still on all its wheels during use. Even when they lock, they’re just not stable enough for my taste unless the machine is really low like a planer. For machines that must move a lot, I like the locking pedal wheels like this one although I’d hesitate to use one on tall machines like a bandsaw.
-- The Wood Nerd -- http://www.thewoodnerd.com
View David Grimes's profile
David Grimes
2078 posts in 2608 days
#5 posted 07-23-2011 11:13 AM
I have the mobile base (assembled but unused) from my HF 2 hp DC. I am about to make a cabinet riser (storage opportunity here as well) to attach to that base to get it up to work table height, then I will top that to support two wood “beams” bevel cut to accept my PortaMate mounts that I already have on my Drill press, Bench grinder, Band saw, Combo sander, and Scroll Saw (all obviously small bench top models). I’ll add a power strip, then a communal dust port for 2 1/2” hose and USE IT.
I’ve planned to do this since I knew I should do something with the metal rolling base months ago. This is now the third personal project down my list, so gimme a minute or three. ;=)
... Putting the Ridgid Jointer Planer together this morning already.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View HorizontalMike's profile
HorizontalMike
7749 posts in 2883 days
#6 posted 07-23-2011 01:05 PM
My TS and my BS are on mobile bases, however my jointer and planer are NOT. My router table is an extension of my TS.
I have my reasons for NOT using mobile bases on everything:
8in JOINTER—pushing large planks of wood across the 8in jointer requires more force than I would be comfortable with when using it on a mobile base.
PLANER—I have built an extended infeed/outfeed table or platform for my planer and think it would be too much/long to work out well on a mobile base. The thing slides easy enough as is so I think having this mobile is a non-issue for me.
NOTE: I am really glad that I placed my BS on a larger square of double 3/4” plywood. The wider stance makes the BS MUCH more stable and the double ply lifts the BS up so that the lower cabinet door misses the base and opens easily.
TheWoodNerd
#7 posted 07-23-2011 10:36 PM
My 8” Grizzly jointer uses one of the locking lever castors like I was referencing. When it’s down, there’s no way it’s moving.
HorizontalMike
#8 posted 07-23-2011 10:50 PM
Hey Nerd,
Do you know if that retractable locking LEVER castor can be retro-fit on any of the older Grizzlys (G0593)?
CartersWhittling
#9 posted 07-24-2011 10:36 PM
Thanks for all the advice. I am leaning towards the pallet jack, that way the tool’s base is directly on the ground, not on wheels.
View pintodeluxe's profile
pintodeluxe
5624 posts in 2782 days
#10 posted 07-24-2011 11:10 PM
I have not had any issues with rocking / tipping while my stationary tools are on Rockler, Dewalt, or Shop-made mobile bases. They sure are handy, and I believe they are worth the high price.
Good luck!
View DamnYankee's profile
DamnYankee
3301 posts in 2531 days
#11 posted 07-24-2011 11:16 PM
I’d never seen a mini-pallet jack before reading this. I like the idea, however my workshop hardly has the floor space to store my hand-truck, let alone a pallet jack.
-- Shameless - Winner of two Stumpy Nubs Awards
CartersWhittling
#12 posted 07-25-2011 12:15 AM
I know a wood worker who made his own jack and it can easily manuever his router table, bench top table saw, and planer. The jack does take up some space, although you can always have it under a machine and out of the way.
View garyjs's profile
garyjs
27 posts in 2451 days
#13 posted 08-23-2011 10:26 PM
I spent many years in Atlanta and in Israel as an ornamental woodworker/turner. I am in the process of converting our 2-car garage to a workshop. To save space, I used the idea of a workstation for small power tools and adapted it my needs. It is a cube 36” on a side and the same in height.
I used two free casters and 2 locking casters to make it easy to move around, and as you can see I added a 4 plug outlet to the top for the bench tools and ran a 12’ exterior extension cord out one side of the box to run power to the outlet. I works a charm, it does.
The interior divider wall is set to proved 10” depth on one open face and close to 25” depth on the other. The narrow shelves are for drill/router bits and other such and the deeper side holds a Skill saw, orbital sander, router, fretsaw and other hand tools.
Hope this helps!
-- garyjs
View dbhost's profile
dbhost
5705 posts in 3201 days
#14 posted 08-23-2011 10:38 PM
A bit more detail on what you actually have would be helpful. Make and model info, perhaps photos, could help us figure out how best to utilize your equipment for space and mobility…
