LARGE miter cut
Forum topic by SoCalDJ posted 698 days ago 1079 views 0 times favorited 19 replies Add to Favorites Watch
View SoCalDJ's profile
SoCalDJ
46 posts in 849 days
698 days ago
Topic tags/keywords: miter speaker large workpiece
So I’m still new to woodworking and had a quick question, after about 3 hours of Google searches and a few wood working forum searches.
I’ve got a 12”x12” 8/4 piece of cherry.
I need to cut it at about a 15 degree angle to that the dimensions are 12”x8” at a 15 degree angle LONGWAYS.
I’ve got a table saw, and a 10” sliding miter saw as two tools to get this accomplished with.
What’s the best way to attack this? this is going to angle a center channel speaker up since it’s sitting on the floor at the moment until I remount my TV and build an entertainment center!
19 replies so far
View WayneC's profile
WayneC
9589 posts in 2295 days
#1 posted 698 days ago
Bandsaw with 12” of cutting depth. Not sure how you would do it with the tools you indicate.
View Arch_E's profile
Arch_E
47 posts in 720 days
#2 posted 698 days ago
Wish that I KNEW THE answer. I don’t. But I do have some warnings: Beware of handling this block at a 15 degree tilt on the tablesaw. That might be “kickback” and/or a blade accident situation. Remember, if it feels wrong, STOP! I’ve got a bandsaw but not 12” of throat clearance. I would expect to have to clean up such a cut from the band saw, since my experience for 10” of resawing in thick (8/4) wood is that the blade can wander.
Now, I’ve got a great set of handsaws (rip and crosscut). I would not hesitate to make such a cut with these. But, I would expect to clean it up, as well, with hand planes. To sum up, the TS lacks the blade depth (and safety) and the BS lacks the guiding mechanism—unless you have a jig to use with the table right tilt. Handsaws might solve this, but it would take patience, and time!!
View Ritty's profile
Ritty
63 posts in 994 days
#3 posted 698 days ago
bandsaw or a couple of dados then use a hand plane in a vise or u could always just make a series of kerf cuts and then knock off the wood with a hammer then sand it, but y use cherry why not plywood?
SoCalDJ
#4 posted 698 days ago
Hmmm. I do have a large handsaws and could clean it up afterwards.
I don’t have a bandsaw yet, and probably won’t for a while, just not enough space in my shop nor funding.
What about unconventional techniques? Could I cut it in two and resaw it on the table/miter saw and then glue it back together? I know this would make the grain not match 100%...
What about a tapering jig of some kind?
SoCalDJ
#5 posted 698 days ago
Because I’ve got this block of cherry sitting unused in my garage at the moment!
How would I setup the cut with the dados on the table saw?
WayneC
#6 posted 698 days ago
Some brainstorming….
A frame saw would be another option…... http://www.hyperkitten.com/woodworking/resaw.php3
Power planer and some sort of Sled…..
Look for a fellow LJ in the area with a large bandsaw….
View Sumdume's profile
Sumdume
40 posts in 1032 days
#7 posted 698 days ago
Have you considered taking it to a local cabinet maker or wood working store and pating them to make the cut safely?
-- Rule # 1 - Don't mix yer blood and sawdust!
View levan's profile
levan
319 posts in 1177 days
#8 posted 698 days ago
Possibly another option might be to rip the board into 1” or so strips and make a three sided frame. I think it would be much easier to bevel the front and taper the sides before assembly. best wishes
-- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View lew's profile
lew
9039 posts in 1953 days
#9 posted 698 days ago
Using the last two posts as a stepping off point. 2-3” wide pieces sliced off of a 2×12 x 12. The whittle away using a jointer. Set the leading edge on the out feed table and push thru- with a push pad. Glue up the finished pieces.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View Loren's profile
5034 posts in 1845 days
#10 posted 698 days ago
While the cut can be done on a bandsaw, realistically I’d bet you would
screw it up.
The cut can be made with relative ease combining the table saw
and hand tools however. Rip to 8”, then cut at an angle on the
table saw from each edge, then finish the cut with a handsaw
guided in the kerfs from the table saw blade. Plane off the
excess and you’ve got two wedges.
I think the angle will be 22.5 degrees assuming your stock is
4 times wider than it is thick.
The easy way is to get 2 pieces of cherry and plane each to
the shape you want.
View 1yeldud1's profile
1yeldud1
235 posts in 1240 days
#11 posted 698 days ago
I think I would try to find a router and construct a set of router “ski’s” – I’d tip this block up on the angle desitred and “surface” the top of the wedge using the router ski’s to establish the 15 degree angle. Please note it would require a “Jig” to hold the block on this angle – BUT it wouldnt be a very difficult project.
View David Kirtley's profile
David Kirtley
1250 posts in 1196 days
#12 posted 698 days ago
It would be pretty easy on a planer or with a hand plane. Prop it up at the angle you want and plane the top off level.
Ritty
#13 posted 698 days ago
u would make one deep dado cut were the most would is needed to be taken off then move down the line making a shallower dado cut untill u dont to make one then alot of sanding or handplaning it would be safer then using the table saw, let me know how it turns out
View Cosmicsniper's profile
Cosmicsniper
2155 posts in 1356 days
#14 posted 697 days ago
A planer would make quick work of this. So would a large bandsaw.
But I think I’d use a large hand saw and then clean it up with hand planes, especially if you precut it on the table saw like Loren said…actually, it’s not all that hard that way.
-- jay, www.allaboutastro.com
View BobTheFish's profile
BobTheFish
362 posts in 750 days
#15 posted 697 days ago
I would use a combination of planes and sanders to get it down.
Use some plywood to cut safer triangles with a fifteen degree angle to act as props to hold your wood at the angle, and maybe a base around it to support the wood and act as an outer “guide” (basically a box holding the wood at a fifteen degree angle). Then plane down till you get near lying “flat” with the sides of the box, and take a belt sander to it to finish it off and take out any uneveness from the narrower planes.
Yes, it’s more work, and yes, there’s more dust and shavings, but it’s far safer, and you’ll have better control over the cut, and less “wobble” from a bandsaw and less danger/ chance of slippage with a table saw….
