rewire an air conditioner?
« back to Coffee Lounge forum
Forum topic by bandit571 posted 665 days ago 959 views 0 times favorited 17 replies Add to Favorites Watch
View bandit571's profile
bandit571
3632 posts in 849 days
665 days ago
If possible. I have on hand a 220V unit (window) that I’d like to rewire down to 110V. Unit has one of the two prong (plus a ground prong) set-up for 220V. I don’t have an outlet available for the 220 plug.
17 replies so far
View Grandpa's profile
Grandpa
2380 posts in 841 days
#1 posted 665 days ago
Does the unit say it will run on 110V ?? I am not sure I have ever seen an air conditioner that would run on both. Maybe lots of them. I am just not familiar with them. The first thing would be to make sure it will operate on 110V. Look into the box or near the box where the cord goes in and see if there is a schematic there that tells you anything.
View rkevins's profile
rkevins
65 posts in 1095 days
#2 posted 665 days ago
I don’t remember ever servicing a window a/c that was dual voltage, not to say they don’t make them as grandpa said you need to look at the diagram or in the manual to find out.
View dbhost's profile
dbhost
4748 posts in 1397 days
#3 posted 665 days ago
Never seen a dual voltage air conditioner. You might have to pull 220V or find a different AC…
View GMman's profile
GMman
3882 posts in 1863 days
#4 posted 665 days ago
If it is 220 the prongs are not straight they are at an angle.
Does it say 220 on it?
Grandpa
#5 posted 665 days ago
I have seen 220V circuits for air conditioners that had 3 prongs on the plug. One round ground like all 110v today uses, one straight up and down (verticle) like all 110V uses today and the third prong was flat but horizontal (opposite of the other flat prong). Those are available and are usually rated at 20 amps.
GMman
#6 posted 665 days ago
Can we see the plug on the end of the cord?
View 000's profile
000
3352 posts in 782 days
#7 posted 665 days ago
it won’t work on 120 unless there’s a clear designation and I ain’t Neer seen one that do gots such a designation.
You can however run it on 220 if you have two 120 lines in the area that each come from different breakers.
Take the hot leads over and that’lll do it just fine. I ran a TS that way for years.
-- When the moderator chooses sides, his site sucks.
Grandpa
#8 posted 665 days ago
cr1, that works only if the 110v circuits are out of phase. If you happen to get lucky you will get 220V and if not you get 110V
bandit571
#9 posted 665 days ago
It was just an idea. The only window this beast will fit is in the kitchen, right above the stove. there are two 220V circuits right under the window. One for the oven/stove, the other for the dryer. Dryer is a three wire set-up, stove is a four wire set-up. Possible to use an old dryer cord to re-wire the a/c for use?
View mrg's profile
mrg
483 posts in 1165 days
#10 posted 665 days ago
If you already have an outlet wired go to the home store and get the correct receptical it’s a 10 minute job.
-- mrg
bandit571
#11 posted 665 days ago
stove and dryer still in use, can I pig-tail two wires out to another box?
Grandpa
#12 posted 665 days ago
Possible but then there is the risk of a problem. pigtail 3 wires out. Than that take a smaller wire out into the open and you are attaching to a 30 AMP breaker for power….....I wouldn’t give advice to do this
bandit571
#13 posted 663 days ago
unit will be in the next yard sale. I have a “loaner” that runs on 110V that is installed right now.
View Jim Jakosh's profile
Jim Jakosh
7238 posts in 1271 days
#14 posted 663 days ago
I’d put a new 220 receptacle in and run it off that! I have never seen a 220/110 air conditioner.
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
View Bertha's profile
Bertha
13111 posts in 858 days
#15 posted 663 days ago
I’m with Jim. I’ve never seen a dual voltage either; and I’ve looked!
