Picking the right screw [gauge]
Forum topic by Spikes posted 08-16-2018 08:05 PM 498 views 0 times favorited 4 replies Add to Favorites Watch
View Spikes's profile
Spikes
125 posts in 285 days
08-16-2018 08:05 PM
Dear all,
noob woodworker here, still working on setting up my space. I’m trying to figure out what kind of screws I should use and, as usual, after days spent asking the same question to google I find myself with a lot more information in my head, but largely the same doubts.
The main pattern I encountered boils down to:
- length should be 1/2 to 3/4 of the “bottom” piece
- gauge #8 for most things carpenterish, with some #10-#12 for larger construction jobs and #6 for “finer” woodworking (cabinets?).
- head is best if torsion or square, or hex head, avoid philips
- use stainless steel
first off, does that make any sense to you? Second, and this is the more direct question I was trying to answer… I’m screwing a 3/4×4x8’ ply panel into a bunch of metal bars on the wall to hang tools off of it… how would I choose which gauge of screws to use so that the panel won’t come off 2 months from now?
thanks as usual,
Spike
-- Don't worry about making progress, worry about practicing. If you practice you will make progress even if you don't want to.
View Woodknack's profile
Woodknack
12466 posts in 2619 days
#1 posted 08-16-2018 08:38 PM
For wood to metal I would use self tapping sheet metal screws.
Wood to wood I eyeball and use whatever looks right. 90% of the time I use #8 screws. I only use #10 or larger for outdoor projects. #6 for 3/4” screws. I’ve gone over to using Spax or GRK although I have occasionally used deck screws. Only time I used stainless is on my boat.
View Rich's profile
Rich
4011 posts in 829 days
#2 posted 08-16-2018 08:48 PM
+1 on GRK and Spax. Probably 90% of the screws I use are #8×1-1/4” which are perfect for working with 3/4” stock. That said, I rarely use screws on anything but jigs and fixtures. My furniture and cabinet projects use traditional joinery or sometimes biscuits when doing face frames. My residential doors don’t use fasteners at all, just mortise and tenon.
View wuddoc's profile
wuddoc
326 posts in 3957 days
#3 posted 08-16-2018 09:53 PM
McFeely’s specializes in fasteners and I believe is now owned by McMaster-Carr.
https://www.mcfeelys.com/screw_size_comparisons
Here is further information on wood screw types including heads, points, etc. from McMaster-Carr.
https://www.mcmaster.com/#wood-screws/=1e6p6zp
-- Wuddoc
Spikes
#4 posted 08-17-2018 02:27 PM
thanks guys, it’s always useful to come here and double check on stuff.
