In Over Your Head
Forum topic by BreakingBoardom posted 672 days ago 1095 views 0 times favorited 36 replies Add to Favorites Watch
View BreakingBoardom's profile
BreakingBoardom
613 posts in 1253 days
672 days ago
Topic tags/keywords: question scroll saw skill
Have you ever started a project and then realized that you’re not skilled enough to complete it to how you would like it to turn out? I was starting a project that I postponed from about 5 months ago and even now I don’t think I’ll be able to finish it and get the results I want. I’m doing a scroll saw project and I don’t want to mess up some nice small exotics so I practiced on cheap stuff and I’m finding that it’s more difficult than I expected and I’m having doubts I can complete it to the standards I want.
Now, the scroll saw I have was given to me for free. It was covered in mud and missing some pieces. I cleaned it up but it’s still no beauty queen. I have to use a pair of pliers to turn it on as the knob is broken. The light and air hose are broken and gone. The blade clamps are slightly rusted. So, needless to say I’m not working with a top notch tool. Also, I have no training on a scroll saw or how to adjust it or anything. I don’t even know what blade I should be using.
Well, sorry for the rant but the question buried 2 paragraphs down here is, have any of you ever done a project where you weren’t skilled enough to do? And how did it turn out if you did complete it?
-- Matt - http://breakingboardom.wordpress.com/
36 replies so far
View DaddyZ's profile
DaddyZ
2008 posts in 1212 days
#1 posted 672 days ago
Get on the Net & read & learn, Then Practise, Practise, & More Practise.
View Bertha's profile
Bertha
13115 posts in 865 days
#2 posted 672 days ago
I ALWAYS tackle WOODWORKING projects that I have insufficient skill to complete. You’ll make it happen. You’ll learn even more along the way. There are a lot of accomplished scrollers here that can help you with your equipment questions. I’m of no use to you there. I’m just here to say go for it.
View crank49's profile
crank49
2291 posts in 1142 days
#3 posted 672 days ago
If you say you can’t, before you start, then you are doomed to fail.
Just do it.
Even if it is not perfect, you will learn.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
BreakingBoardom
#4 posted 672 days ago
Thanks guys, I started on this last night and did get a pretty good start but I need to scroll saw some small letters and I think it’ll take quite a bit of practicing before I cut into the good wood. I have I think 3 different kinds of blades so hopefully one of them will work for the small letters.
Bertha
#5 posted 672 days ago
Post the type of wood, thickness of wood, and type of saw. The scrollers here will have precise blade recommendations, no doubt.
14865 posts in 2390 days
#6 posted 672 days ago
I ALWAYS tackle projects that I have insufficient skill to complete
What kind of doc did you say you were, Al? :-)
Bertha
#7 posted 672 days ago
^Charlie, I clearly specified “woodworking” projects; check my post ;) !!!
BreakingBoardom
#8 posted 672 days ago
Well, I’m going to be using either Maple & Paduak, or Walnut & Paduak and they’ll be 1/4” thick each. The POS Saw I have is a Ryobi SC180VS I believe. It takes both pinned and plain end blades (according to the specs and manual). Right now I just have plain end blades. Any suggestions for blades from any of the scrollers out there?
View Don W's profile
Don W
9972 posts in 739 days
#9 posted 672 days ago
If your not pushing the envelope, your not having fun!
#10 posted 672 days ago
LOL @ Bertha!
View rogerw's profile
rogerw
265 posts in 861 days
#11 posted 672 days ago
practice makes perfect. my first scrollsaw project wasn’t even close to pretty but i have gotten quite good at it although i don’t consider myself an expert my any means. but confident i am.
the internet is a wealth of information on both setup and use.
you’ll do fine. don’t let it scare you. it’s only wood!
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
12071 posts in 1513 days
#12 posted 672 days ago
check out sheilas class in scrolling
you can send her a pm too
http://lumberjocks.com/scrollgirl/blog/24198
View Elizabeth's profile
Elizabeth
639 posts in 1315 days
#13 posted 672 days ago
I ask lots of questions, get as much information as I can, give it my best shot, and try to ignore the people who tell me I shouldn’t try or are sarcastic about my questions. My first bandsaw box was a near-complete failure. Looking forward to making my second!
BreakingBoardom
#14 posted 672 days ago
Thanks Patron. Checking out Sheila’s class now.
View Manitario's profile
Manitario
1862 posts in 1055 days
#15 posted 672 days ago
started making a bedframe for a king sized bed this past winter. After some painful slogging away at it, and some expensive wood wasted, I realized that I just didn’t have the skill set, or patience yet to complete it. Was a blow to my ego, but I survived.
-- Rob, Sault Ste. Marie, Ontario
showing 1 through 15 of 36 replies
