What kind of Joint and How?
« back to Joinery forum
Forum topic by Freemotion posted 08-16-2018 12:44 AM 792 views 0 times favorited 11 replies Add to Favorites Watch
View Freemotion's profile
Freemotion
4 posts in 92 days
08-16-2018 12:44 AM
Topic tags/keywords: joints joinery japanese joinery lap lap joint joint
Hi Everyone,
I’m trying to figure out what kind of joint this is?
Lap joint? Japanese joinery (is there a name for it?)
How would I go about making it?
Many, many thanks.
P.S. I’ve been googling for a while and just could not get the results, so I’m asking the pros here :-)
11 replies so far
View Rayne's profile
Rayne
1091 posts in 1713 days
#1 posted 08-16-2018 01:10 AM
Looks like a 3 member half-lap joint. Found this on Bing, but it was also mentioned in another post here.
http://lumberjocks.com/topics/149674
View jbay's profile
jbay
2748 posts in 1072 days
#2 posted 08-16-2018 03:40 AM
Simply just 3 birdsmouth cuts. Same cut in each piece.
Dado blade set at 30 degree angle should do it.
Depending on the size of your wood,
you might have to make a couple of passes with the dado blade, adjusting the height for each pass.
The depth of the cut, and the distance from the edge, should be the same.
-- “Hanging onto resentment, is letting someone you despise live rent-free in your head.” (Ann Landers)......
View Aj2's profile
Aj2
1790 posts in 1971 days
#3 posted 08-16-2018 04:20 AM
What is that particular joint used for. I can’t think of any use.
Jbays tip make sense to me.
-- Aj
Freemotion
4 posts in 92 days
#4 posted 08-16-2018 04:33 AM
- jbay
Hey that’s awesome jbay! That’s pretty much exactly it!
I was wondering if there was any bottom lap component, or if it would be possible,
but your diagram reveals it all.
When you say dado blade at 30 degrees it made me understand that I could just
run it through the table saw, instead of a band saw, thanks! :-)
Aj2-
Here is where I saw the joint:
View Aj2's profile
Aj2
#5 posted 08-16-2018 05:45 AM
Oh I see a modern style coat rack. Very cleaver.
Now that’s behind us let’s start working on this one. :)
-- Aj
View robscastle's profile
robscastle
5387 posts in 2377 days
#6 posted 08-16-2018 09:05 AM
Freemotion
4 posts in 92 days
#7 posted 08-16-2018 08:34 PM
http://lumberjocks.com/robscastle/blog/115586
- robscastle
Rob,
That’s amazing, thank you. Definitely, gives me some great starting points!
View Breeze73's profile
Breeze73
98 posts in 854 days
#8 posted 08-17-2018 03:41 AM
While it looks pretty neat, I believe that is all it could be used for… looks. It’s nothing more than end-grain glued to long grain, like a simple butt joint. It looks pretty weak and would likely fail fairly easily.
-- Breeze
View AlaskaGuy's profile
AlaskaGuy
4632 posts in 2482 days
#9 posted 08-17-2018 04:09 AM
While it looks pretty neat, I believe that is all it could be used for… looks. It s nothing more than end-grain glued to long grain, like a simple butt joint. It looks pretty weak and would likely fail fairly easily.
- Breeze73
Looks like a strength test for Matthias Wandel. A simple butt joint can be pretty strong depending on the direction the load comes from.
View Lazyman's profile
Lazyman
2559 posts in 1561 days
#10 posted 08-17-2018 04:13 AM
Here is a more complex way to make a similar joint with half laps that is probably stronger because it’s not just endgrain glue joints. I think I’ve seen this used for stretchers on a 3 legged stool somewhere on LJ but cannot seem to find it now.
http://lumberjocks.com/replies/1129873
View BurlyBob's profile
BurlyBob
5936 posts in 2439 days
#11 posted 08-17-2018 03:07 PM
I totally agree with jbay.
