Bits for drill press
Forum topic by bill66 posted 08-15-2018 09:54 PM 427 views 0 times favorited 7 replies Add to Favorites Watch
View bill66's profile
bill66
8 posts in 620 days
08-15-2018 09:54 PM
I recently purchased a jet drill press with 1/2 horse motor and did not pay close enough attention to the spindle speed. To my chagrin the slowest speed on the variable speed machine is 530 rpm. What is the largest forstner bit I can run? Is there a work around for larger bits such as pausing during drilling?
Thank you for your help.
7 replies so far
View John Smith's profile
John Smith
1441 posts in 337 days
#1 posted 08-15-2018 10:01 PM
Bill, I don’t know the “correct” speed for a Forstner to be effective.
but, for me, I get better results with a fast RPM and constant
downward force – really pushing down on the bit. I have forstners up to 2”.
slow speeds and hesitating creates a hot bit and smoke – not good.
practice with your tools will put you in the comfort zone of your skill level.
and of course, a really sharp bit helps.
jus my Dos Centavos
-- I started out with nothing in life ~ and still have most of it left.
View Woodknack's profile
Woodknack
12399 posts in 2554 days
#2 posted 08-15-2018 10:01 PM
Google, “drill bit speed chart” you’ll find about a thousand and two charts covering all sorts of bits.
View TheFridge's profile
TheFridge
10500 posts in 1660 days
#3 posted 08-15-2018 10:11 PM
600 sounds plenty low enough to make it work.
View BurlyBob's profile
BurlyBob
5936 posts in 2439 days
#4 posted 08-15-2018 11:29 PM
Another thing for certain. Make darn sure your Forstner bits are sharp. I use a 3” bit frequently and I’ve found I need to keep it sharp, real sharp. Speaking of that I need to give it some love tomorrow.
bill66
8 posts in 620 days
#5 posted 08-16-2018 01:05 AM
Great comments from everyone. Sounds like my concerns were unfounded. Thank you
View ArtMann's profile
ArtMann
1105 posts in 990 days
#6 posted 08-16-2018 03:02 AM
Your problem is horsepower, not rpm. It takes a lot of power to cut easily with a big Forstner bit. I cut 2.25 – 3 inch holes for mounting clock movements in hardwood at 640 rpm. My drill press motor is 1 horsepower and it isn’t a bit overpowered. I could stall the motor fairly easily if I tried. I agree with BurlyBob that a sharp bit makes a world of difference.
View robscastle's profile
robscastle
5387 posts in 2378 days
#7 posted 08-16-2018 09:18 AM
500 RPM or thereabouts is as slow ay you will get.
Needed to make hundreds of these suckers.
Initial attempts to use a forstner bit in a drill press failed, too slow too hard.
Gave up, ... and used a router, template guide and bushing
The template guide
The result.
-- Regards Rob
