Saw blades
Forum topic by bblogna posted 07-21-2011 10:46 PM 1032 views 0 times favorited 8 replies Add to Favorites Watch
View bblogna's profile
bblogna
26 posts in 2627 days
07-21-2011 10:46 PM
Any disadvantages to using a 7and 1/4 inch blade in a 10 table saw other than depth of cut?
8 replies so far
View lew's profile
lew
12017 posts in 3719 days
#1 posted 07-21-2011 10:54 PM
Check with the manufacturer for the max specification on rpm’s
View cabmaker's profile
cabmaker
1720 posts in 2772 days
#2 posted 07-21-2011 11:28 PM
No dis advantage at all as long as the blade you use gives the desired results. I used to do it often on job saws or even in the shop when regular blades became dull, out for sharpening,etc. It will feel like you added more hp to your saw. Im sure your going to hear responses about blade deflection, overspinning,dah ta dah,etc. Just do it.
View crank49's profile
crank49
4030 posts in 2934 days
#3 posted 07-22-2011 12:19 AM
If your saw is a newer model with a riving knife, there is a possibility you might not be able to make non-through cuts without removing the knife because it will protrude above the blade. Not a problem with through cuts, however. Depends on the saw and mounting of course. On my saw the knife is above the blade, level with the blade, or below the table. Just 3 choices.
View Viktor's profile
Viktor
463 posts in 3382 days
#4 posted 07-22-2011 12:58 AM
Your splitter/riving knife might not fit into the kerf from 7 1/2 blade. Other than this only advantages: less waste, less noise, easier on the motor. I did not notice any deflection comparing to 10” blade. 7 1/2” could be twice as thin as 10”, but it is somewhat compensated by smaller diameter.
View knotscott's profile (online now)
knotscott
7980 posts in 3339 days
#5 posted 07-22-2011 01:26 AM
There are advantages and disadvantages to just about everything in the mechanical world. How you view them depends a lot on your needs and situation. The radius of a 7-1/4” blade is much tighter, so the attack angle will change vs a 10” blade…similar to increasing the hook angle. There can be pros and cons to that, but it’s likely to leave slightly more tearout than the same configuration on a 10” blade. The smaller blade can be easier to spin if your saw is underpowered.
bblogna
#6 posted 07-22-2011 03:29 AM
I have a ridgid R4510 jobsite saw. Idont really find it under powered but do think the smaller blade will help and the riving knife is removable so kerf isnt a problem.Might make a zero tolerance insert to help with the tearout. Thanks for all the input was just wondering if anybody else tried this.
View Grandpa's profile
Grandpa
3259 posts in 2639 days
#7 posted 07-22-2011 03:34 AM
Most 10 inch saws run about 3500 RPM. Most portable saws run about 5500 to 6000 RPM. The blades are designed to operate at those RPM’s. Operating a blade at a lower RPM should not hurt a thing. The 10 inch blade passes X number of inches of blade per second past the table. The 7 inch blade will pass (turns the same RPM with a smaller radius) fewer inches of blade past the table so it seems that it would cut slower. Fewer teeth go past the wood you are cutting with the smaller blade. Does it hurt anything? No, not unless it messes up your wood in some way.
View Dusty56's profile
Dusty56
11819 posts in 3651 days
#8 posted 07-22-2011 03:37 AM
Yes , this subject has been brought up several times here on LJs already.
The “search” button is an excellent feature to make use of : )
I have been using the smaller blades for years with no problems at all .
