What Finish???
Forum topic by puzzled posted 04-02-2008 03:09 PM 818 views 0 times favorited 4 replies Add to Favorites Watch
View puzzled's profile
puzzled
72 posts in 3661 days
04-02-2008 03:09 PM
Good morning everyone.
I am working on an ambrosia maple hollow form and I want that “glass” look that you see on some turned pieces. I have sanded the vessel down to 400 and applied 4 coats of clear gloss. I am going to re-sand tonight and would like to know what will give me that deep wet look. If anyone has any other suggestions on finish that work well for them, please let me know. I dont have any pics at the moment, but I will get some after I finish it.
Thanks
Trey
-- -- Remember, a chip on the shoulder is a sure sign of a woodturner.
View odie's profile
odie
1691 posts in 3709 days
#1 posted 04-02-2008 03:20 PM
This is what I use: several coats of tung oil after sanding to 2000 grit. Make sure you get all excess tung off quickly. Don’t wait the full soak in time. Let dry at least 24 hours between coats. Lightly steel wool between coats also. Use steel wool to apply a first coat of good furniture paste wax. Then apply a couple with a cloth after. Your wood is usually quite porious, but I know this to work on harder maple. Good luck … this is what I do with nonusable turned items.
View GaryK's profile
GaryK
10262 posts in 3857 days
#2 posted 04-02-2008 04:38 PM
I think lacquer will get you the glossiest finish.
27251 posts in 3691 days
#3 posted 04-02-2008 05:14 PM
Hi Trey,
Just keep in mind that the higher the gloss of your finish the more likely it is to show scratches and other flaws so good stock preparation and sanding is an absolute necessity.
Good luck.
View rikkor's profile
rikkor
11295 posts in 3744 days
#4 posted 04-02-2008 09:34 PM
I am looking forward to seeing the finished project.
