Recommend a Shaker Raised Panel Set?
Forum topic by Bertha posted 07-21-2011 05:20 PM 8355 views 2 times favorited 17 replies Add to Favorites Watch
View Bertha's profile
Bertha
13506 posts in 2598 days
07-21-2011 05:20 PM
Hey LJs, I’m in the market for a simple 1/2” Shaker (straight panel-raiser) router bit set for raised panel doors. I’d prefer one with an undercutter, capable of 3/4” and 1” thickness. My router is 3+ hp and VS.
Anyone had good experience with a similar set? I’d like to come in under $200. I’m looking at Freud, Sommerfield, Amana, Woodline, MLCS.
Any help appreciated!!!!
17 replies so far
View blackcherry's profile
blackcherry
3337 posts in 3728 days
#1 posted 07-21-2011 05:46 PM
Hey Bertha try this site www.woodworkersworld.net , this site sell whiteside bits and I believe you should get free shipping with what you purchasing…good luck…Blkcherry
Bertha
#2 posted 07-21-2011 05:48 PM
Thanks, Cherry! I hadn’t considered Whiteside, although I own many of them. My fiance’s got some kind of free shipping scam through Amazon and I always get reprimanded when I go somewhere else. I’ve been happy with my Freud Quadras, but they’re a bit proud of them ($). Thanks for the idea!
View superstretch's profile
superstretch
1531 posts in 2598 days
#3 posted 07-21-2011 05:52 PM
Amazon Prime? Its a wonderful thing
-- Dan, Rochester, NY
View bandit571's profile
bandit571
19195 posts in 2588 days
#4 posted 07-21-2011 06:02 PM
I don’t use router bits to make my shaker raised panels. Just a couple set-ups on the tablesaw works for me. Two passes per edge. One does the “flat” part, the second pass does the beveled part. How much bevel is up to the operator of the saw (me? about 15 degrees)and one needs to set the height so that the bevel cut just nicks the flat cut. In my Project gallery, you’ll find a Cedar Chest with raised panels done this way.
Bertha
#5 posted 07-21-2011 06:18 PM
I believe so, Stretch. I found an MLCS 3-piece for $90 and 6-piece for $115. 1/2 inch with undercutters. Works up to 3/4 inch. The CMT’s look pretty nice, as well.
Bandit, most of the raised panels I’ve done have been on the shaper but I’ve used the TS will good results. I’ve just got a fancy new router table and my TS and RAS are dialed in for rip and cross-cut, respectively. I’d like to be able to blast out simple panels with a minimum of machine fussing. I’m figuring with above the table bit changes and setup blocks, I can rip on the TS, cross on the RAS, and shape the panels without a lot of fuss. I’m also using a current project as an excuse to get more tools;)
I’ve got a vintage TS and once I cant the blade, there’s always a bit of tweaking to get it back square. Putting a massive panel raiser in a horizontal router table always makes me a bit nervous, so your advice is very well taken.
View Maveric777's profile
Maveric777
2693 posts in 2982 days
#6 posted 07-21-2011 06:33 PM
I have had a lot of success using MLCS sets. I love mine! Plus the $165 price tag (no tax and no shipping charge) was a huge plus as well….. I normally go to them for all my router bits…. Cool company…
-- Dan ~ Texarkana, Tx.
Bertha
#7 posted 07-21-2011 06:38 PM
^Thanks, Dan. I have several and they’re of good quality. I’m really happy with my Sommerfield stuff, too. The price is right on the MLCS, given that they’re a solid $50 below the competitors. I’m not in need of a perfect finish; I’d just like the rails and stiles to get along with each other. I can always swap out the panel raiser for an ogee, etc. I just want to transition from the shaper to the table without breaking the bank.
View knotscott's profile
knotscott
7873 posts in 3281 days
#8 posted 07-21-2011 09:58 PM
As much as I tend to favor Infinity and Whiteside bits for my critical more expensive bits, the Freud 2+2 panel raisers do have a design advantage. I wouldn’t opt for an Asian import for this application….my logic is that it’s too much money to not get a premium bit….especially if you’ll be doing any quantity of them.
Bertha
#9 posted 07-21-2011 10:10 PM
Knott, I looked hard at the infinity. The Whitesides were about the same price as the Freuds. I opted to save $85 or so and restricted myself to the 3/4” stock (which may end up being a bad mistake). The Freud set I wanted was quite a bit more, although I’ve been very happy with my limited collection of Freud Quadra’s. I only got a Straight panel raiser in my set. When I decide to add profiles, I’ll probably piece out the Freuds. I found a Stone Mountain set for REAL cheap, but I was too timid. Lonnie’s got some pretty nice ones, as does Amana. I’ve spent so much on shaper knives in the past that my wallet doesn’t get happy about buying router bits.
I went with this one at Amazon with free shipping:
MLCS 8391 Shaker Raised Panel Door Cabinetmaker Set, 5-Piece
by MLCS
Price: $114.95
Thanks for all the help. I’ll let you know how I like them.
View SouthpawCA's profile
SouthpawCA
269 posts in 3138 days
#10 posted 07-21-2011 11:04 PM
I recommend Eagle America. They have excellent bits plus muxh of what they sell is Made in USA though they do carry pricecutter imports also … make sure you check them out
http://www.eagleamerica.com/prod_detail_list/s?keyword=shaker
-- Don
Bertha
#11 posted 07-21-2011 11:10 PM
Thanks, Don! That’s a solid looking bit and for $179, not a bad price at all. For those who haven’t seen them:
View jumbojack's profile
jumbojack
1673 posts in 2529 days
#12 posted 07-22-2011 12:59 AM
Bertha, I chose the stacked Shaker Style bit from MLCS because I thought having one bit do two jobs was a novel idea. Turns out it is not only novel but practical as well. Let me say I am not a seasoned woodsmith and found the set up pretty simple. I did a mock up with some scrap and made some adjustments (two) and had perfect alignment. I think the use of a sled of some sort for the cope cut is essential. I also learned to run everything through a thicknesser of some ilk. Consistent pressure on the cuts is critical. Some light sanding on the profile was needed (I used poplar) as there was just a little fuzz. Overall I found the bit to do the job and since it is probably a one time use I found the cost to be on par with the task.
Dont hesitate to shoot me a message with any ? or comments.
Jack
Bertha
#13 posted 07-22-2011 02:05 AM
Thanks Jack! I’ll probably make a setup block out of UHMW plastic once I get the bit dialed in. I’m just using it for shop cabinetry, so absolute perfection is not really required. I’ve always prefered the straight panel style, so I’ll probably end up using it more than I think. I had a similar 3” set for my shaper when I redid my New Orleans kitchen (killed by Katrina). If I run into any hiccups, I’ll shoot you a message. Thanks for the offer!
Bertha
#14 posted 07-28-2011 08:34 PM
Hey! My MLCS bitset came in yesterday from Amazon. Took a week or less. They came in a nice box with sketches of the bit profile. There’s 1) two-wing raised panel with undercutter, 2) rail, 3) stile, 4) gluejoint, and 5) drawer lock. It also came with a little bag of shims, washers, and nuts. I ran some pine over the first 3 bits last night. The panel and stile match up easily but the rail needs some work. I made a few test cuts, each progressively worse. I think I might shim the panel receiver a bit wider and make up the play with spaceballs. All in all, for a 2-wing cutter, for $120, I’m pretty happy. I’ll let you know about the gluejoint after tonight but I doubt I’ll ever even use the drawerlock.
View S4S's profile
S4S
2118 posts in 2586 days
#15 posted 02-13-2012 04:27 PM
Does HF carry something like that ?
