Scarfing trim joint
« back to Joinery forum
Forum topic by RobS888 posted 08-13-2018 04:05 PM 589 views 0 times favorited 5 replies Add to Favorites Watch
View RobS888's profile
RobS888
2523 posts in 2083 days
08-13-2018 04:05 PM
Hi,
I have several pieces of trim to put up in a 14’ x 14’ foot dining room and all I have is rough 8’ red oak. I did a smaller room and tried butt joints (pretty bad) and a scarf joint (meh). I was adding the second piece to an existing piece. I think I’m going to try scarfing the pieces together before installing, the pieces are part of a craftsman trim approach and will only have medium walnut Danish oil on them, so caulk and paint are out to hide the joint.
I know some people use biscuits to join pieces of trim together before attaching, but I was thinking of a scarf joint with maybe a 30 degree angle.
Anyone tried anything like this?
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
5 replies so far
View rwe2156's profile
rwe2156
3230 posts in 1719 days
#1 posted 08-13-2018 05:20 PM
Glueing together and installing as one piece is definitely the way to go with trim. For scarf joints I usually use 22.5° simply because that is more reproducable setting on a miter saw.
Lots of trim guys use cyanoacrylate glue. I don’t know who well that would work on red oak, with its extremely porous endgrain. You may have to size it first. Worth testing out.
View builtinbkyn's profile
builtinbkyn
2686 posts in 1179 days
#2 posted 08-13-2018 06:11 PM
..... I was thinking of a scarf joint with maybe a 30 degree angle.
- RobS888
Use splines, loose tenons or half lap. Butt join them. Or you can even use pocket holes, but I think one of the first three would be better.
-- Bill, Yo!......in Brooklyn & Steel City :)
View bilyo's profile
bilyo
474 posts in 1341 days
#3 posted 08-14-2018 03:44 AM
With a well done glued scarf and matching grain to the extent possible, the joint will nearly disappear.
View Woodknack's profile
Woodknack
12465 posts in 2618 days
#4 posted 08-14-2018 06:06 AM
- bilyo
+1
I’ve done scarf joints, in trim and on stringed instruments. They are very strong and as said above, if the grain is well matched are not very noticable.
RobS888
#5 posted 08-14-2018 02:00 PM
Thanks guys, I definitely want to sand and finish this as one piece.
