Using a regular plane iron in a Krenov-style plane
« back to Hand Tools forum
Forum topic by Ripthorn posted 07-20-2011 09:36 PM 1561 views 0 times favorited 2 replies Add to Favorites Watch
View Ripthorn's profile
1454 posts in 2916 days
07-20-2011 09:36 PM
Topic tags/keywords: plane
Has anyone used a regular old Stanley-styled plane iron in a Krenov-style plane? I know that Hock makes some awesome irons, but before I drop the dough on one, I want to see how much I will use a wooden-bodied plane. I may make a test plane to try it out, but just curious if anyone has done the same thing and what they think of it (chipbreaker or no, wedge thickness, etc.).
2 replies so far
View Loren's profile
10084 posts in 3579 days
#1 posted 07-20-2011 09:49 PM
I have. A standard iron works better with a chipbreaker, but
block plane blades can be used effectively without a chipbreaker
in home-made planes provided the wedge is shaped right, which
does take a bit of practice.
View WayneC's profile
13751 posts in 4029 days
#2 posted 07-21-2011 12:39 AM
You might also be able to find one intended for a wooden plane on ebay or at a flea market. I sometimes see them. I’ve also seen folks use old block plane blades. Using a standard blade may not give the same results as a Hock Blade or one from David Finck if your trying to get a true evaluation…
Lee Valley also sells blades,41182,43698&ap=1
