"Buttered toast"
« back to Coffee Lounge forum
Forum topic by KnickKnack posted 672 days ago 690 views 0 times favorited 12 replies Add to Favorites Watch
View KnickKnack's profile
KnickKnack
805 posts in 1736 days
672 days ago
It’s well known that if you drop a piece of buttered toast it will land buttered side down on the floor (not sure about margarine).
I’ve found that, at least in my ‘shop, there’s a woodworking version of this…
  • Whenever I drop a sharp chisel, it invariably lands on the sharp edge, usually chipping it
  • If I drop a piece of wood with a fragile part, it invariably lands on the delicate part, often breaking it
  • If I drop a flat piece of wood, it invariably finds a sharp point on which to land, invariably piecing the face I’ve just spent the last hour sanding/scraping to a mirror finish.
  • If I drop a rag I’m using for oiling, it will float downwards, drifting towards the largest pile of sawdust on the floor.
Am I just unlucky, or is this a well-known fact of woodworking?
-- "Do not speak – unless it improves on silence."
12 replies so far
View DLCW's profile
DLCW
505 posts in 824 days
#1 posted 672 days ago
This is a fact of woodworking. Add to this:
When under the gun to get a project finished, a tool/bit/blade needed to complete the job breaks.
Lean a just completed board against the wall making sure it is secure and won’t move and somehow it will fall over (maybe a spider or mouse pushed it).
When spraying the final coat of finish on a beautiful piece, the sprayer clogs and then spits out a big goober that lands in your finish.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
KnickKnack
#2 posted 672 days ago
What a great image!
Rick Dennington
2889 posts in 1364 days
#3 posted 672 days ago
  • I like the spider or mouse theory.....that could explain why things happen for no reason. All of a sudden it’s where it’s supposed to be, and the next it’s on the floor where it’s not supposed to be…..been there…done that on more than one occasion….By the way, Don, where I’m from in the South, a goober is a peanut*...lol.
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
View Don Johnson's profile
Don Johnson
536 posts in 950 days
#4 posted 672 days ago
I’ve been learning that:
If you need three screws – you will find two (etc)
If something can fall and roll under something big, heavy and with a small gap – it will
If you move something with a cable attached – the cable will catch on something
If your power tool has a dust collection outlet – it will be just too big to go on the end of the hose
If you have a certain type of wood that would suit a project – there will be just enough (‘till you ruin one bit!)
and . . . . If I put something down in plain view, it will disappear into the fourth dimension until my wife comes in and points at it!
-- Don, Somerset UK, http://www.donjohnson24.co.uk
View Viking's profile
Viking
858 posts in 1364 days
#5 posted 672 days ago
All variants on Murphy’s Law!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View Elizabeth's profile
Elizabeth
639 posts in 1313 days
#6 posted 672 days ago
“If I put something down in plain view, it will disappear into the fourth dimension until my wife comes in and points at it!”
Heehee…this happens with my husband and finding things in the fridge.
KnickKnack
#7 posted 672 days ago
Hey Don – I’ve seen your stuff there in the 4th – but where’s mine?
View William's profile
William
7072 posts in 1012 days
#8 posted 671 days ago
Dust will fly towards the direction of your face, but only when you forgot to put on your safety glasses.
Your wife will have the best ideas on how to make a particular difficult technique easier, just as soon as you have just finished said technique.
You will run out of finish, about two thimble fulls before you complete the finish on your project.
View gfadvm's profile
gfadvm
6635 posts in 859 days
#9 posted 671 days ago
You will break your 11/64 drill bit on the next to last hole of your project at 9:45pm on Sunday. Afly will be seen doing the backstroke in the 20th coat of poly when its too tacky to leve
View Manitario's profile
Manitario
1862 posts in 1052 days
#10 posted 671 days ago
If you mess up a cut, it will always be to cut the board too short, not too long.
If you drop a board just after applying a bead of glue, it will always land glue side down.
-- Rob, Sault Ste. Marie, Ontario
View bubinga's profile
bubinga
867 posts in 837 days
#11 posted 671 days ago
Why do the little gnomes always steel , the, blade, bit, tool, screw,nut, bolt,etc that I NEED ?
And only one sock at a time ?
-- E J ------- Always Keep a Firm Grip on Your Tool
View SchottFamily's profile
SchottFamily
110 posts in 662 days
#12 posted 661 days ago
I’ve got 5 kids – I don’t need any supernatural forces to add to my dismay in the shop ;)
-- IZZZZZI BoB IZZZZZI
