sharpening
Forum topic by jimboy posted 07-20-2011 08:47 AM 1868 views 0 times favorited 19 replies Add to Favorites Watch
View jimboy's profile
jimboy
28 posts in 2847 days
07-20-2011 08:47 AM
Any member know how to sharpen a circular saw blade with tungsten teeth, I have tried a diamond hone with little success, and a dremel with a small grinder with limited success, any help would be appreciated
19 replies so far
View David Grimes's profile
David Grimes
2078 posts in 2843 days
#1 posted 07-20-2011 08:59 AM
If you mean 7 1/4” saw blades, they are so cheap that I find it not worth the effort to sharpen them.
Harbor freight has an inexpensive sharpener. I would love somebody on here to try it and let me know how it really works. 12” and 10” blades would be worth the effort in my book.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View canadianchips's profile
canadianchips
2613 posts in 3201 days
#2 posted 07-20-2011 12:42 PM
You can buy a Diamond wheel for your dremel tool.(1 inch diameter, cost her is $2.) I use mine to sharpen my carbide tip blades.
View TheWoodNerd's profile
TheWoodNerd
291 posts in 3395 days
#3 posted 07-20-2011 01:18 PM
Every review I’ve seen of the HF sharpener is that it’s horrifyingly bad.
-- The Wood Nerd -- http://www.thewoodnerd.com
David Grimes
#4 posted 07-20-2011 01:34 PM
That’s why I want somebody else to try it and heads up ;=)
View gdpifer's profile
gdpifer
47 posts in 2884 days
#5 posted 07-20-2011 01:46 PM
Having operated a sharpening service for over 10 years I was interested in looking at the HF machine since a good carbide sharpener costs thousands of dollars and it was about $50.00. Not too impressed. It won’t allow you to sharpened the tops, juist the face. The diamond wheel looks pretty thin and cheap. Might do a bit to help a cheap saw blade but I woudn’t want to use it on a good blade.
-- Garry, Kentucky
jimboy
#6 posted 07-20-2011 09:48 PM
Thanks for al the replies, I use a 10” blade in my saw and they are hard to get, I normally buy the Ryoibi blades as they are the cheapest and last for a long time but as I am cutting a lot of recycled timber I hit the occasional nail which dulls the teeth.
The dremel diamond wheel sound like it may work but as I like down under I may not be able to get them here I will check the local hardware
Jimby
View Don W's profile
Don W
19017 posts in 2771 days
#7 posted 07-20-2011 10:27 PM
I have one of those sharpeners. I’ll give you a good deal on it :-)
View Jeffery Mullen's profile
Jeffery Mullen
355 posts in 3021 days
#8 posted 07-26-2011 10:06 AM
I just leave my saw blade in my table saw and use a very small half inch cut off wheel that is used to cut the ends of nails off a project that sticks out. I mount the cut off wheel to my dermal and sharpen away. I guess I just have an eye for it. I even learned how to use my cut off wheel with my dermal tool to sharpen serrated steak knifes. Later Jeff M.
-- Jeffery Mullen
Don W
#9 posted 07-26-2011 05:10 PM
Jeff, next time you tackle that job, it would make for a very popular blog.
View Bertha's profile
Bertha
13551 posts in 2897 days
#10 posted 07-26-2011 05:45 PM
Jimboy, where do you live where 10” blades are hard to find!? I’ve been using throwaway DeWalts and Diablos, although I have a nice Forrest for the good stuff. I buy a pack of two 40 tooth Dewalts for around $30; one for the ts and the other for the RAS. I would try to sharpen them with a diamond Foredom tool but like David says, for $15, it’s hardly worth the effort. I wouldn’t risk ruining my $100+ Forrest so when the time comes, I’ll send it out to the pros like Garry. I’d imagine the HF is like a giant drill doctor, cool in principle, but too good to be true.
David, I’ve been waiting for a headsup on their bandsaw welder for the same reason!
jimboy
#11 posted 07-26-2011 10:10 PM
I am in NZ and the reason these blades are hard to find is that they are a popular size for saw benches and being a small country we get what the retailers bring into the country
Thanks for all your help
Bertha
#12 posted 07-26-2011 10:13 PM
Ah, I missed the NZ part. That’s a drag. Good luck!
Jeffery Mullen
#13 posted 07-29-2011 09:16 AM
a friend of mine bought allot of power shop tools and some of them he hasn’t opened yet since he bought them. one day I was in his shop visiting and noticed he had a electric saw blade sharpener that sharpens table saw blades from 4 inches to 15- 3/4 Diameter. It is a Chicago electric power tool. the motor turns at 3800 RPM while sharpening a saw blade. I am dying to try this tool out. My friend said if I can figure this tool out to show him how as well LOL. Like I said above I use my dermal to sharpen most my stuff but this tool should be fun to try out.
-- Jeffery Mullen
View MrRon's profile
MrRon
5202 posts in 3447 days
#14 posted 07-29-2011 08:13 PM
I used to have a saw sharpening service out of my home. Carbide tip blades are easy to sharpen, but you have to have the right machine to do it properly. Doing it by hand with a Dremel doesn’t work. You have to use a machine that can repeatably index each tooth accurately and do face, side and top grinds. Such machines cost over $1000. You are better off sending the blades out to a professional sharpening service. I only do my own blades now.
P.S. If you are cutting through nails, the chances are good that some teeth have gotten chipped beyond sharpening and have to be replaced and that is a whole different ball game.
jimboy
#15 posted 07-30-2011 09:48 PM
Thanks MrRon for the info but having blade sharpened in NZ is nearly as dear as buying a new blade this why I am looking at ways to touch up a dull blade
