bandsaw blade TPI
« back to Woodturning forum
Forum topic by Karda posted 08-11-2018 04:31 AM 359 views 0 times favorited 9 replies Add to Favorites Watch
View Karda's profile
Karda
1172 posts in 635 days
08-11-2018 04:31 AM
Hi, I have had 3 and 4 tooth band saw blades, I need to order a new one. My question is what is better for cutting bowl blanks a 3 tooth or a 4 tooth. I have had both but not at the same time. I can’t remember if there is a difference. my memory is getting like that. Thanks Mike
9 replies so far
View Lazyman's profile
Lazyman
2276 posts in 1469 days
#1 posted 08-11-2018 12:18 PM
It won’t make that much difference but if you cutting green, wet wood, I would probably opt for fewer teeth to ensure maximum sawdust clearing, especially since in blank prep you don’t care about the quality of the cut.
View Woodmaster1's profile
Woodmaster1
1024 posts in 2668 days
#2 posted 08-11-2018 04:35 PM
I lucked out and got a carbide tooth 3/4” x 93 1/2” 3 tpi off the discount get it out of here rack for $5.00. I love going to my woodworking store when you can get bargains like that. I put it on my 14” porter cable bandsaw and it works great. There is no issues with power because it has a 1.5 hp motor.
View BurlyBob's profile
BurlyBob
5820 posts in 2347 days
#3 posted 08-12-2018 02:12 AM
My question is just how thick is your piece? I’ve found that on a thinner piece a higher TPI makes for a smoother cut. I do a lot of cutting with a 1/8×14TPI. The reason is for tight curves and a cleaner cut on thinner pieces. I use a 1/4” by 4TPi for cutting band saw boxes 4”-6” thick. Resawing – 1/2” 3-4TPI. It all depends on the task.
Honestly, either one will work.
Karda
#4 posted 08-12-2018 06:46 AM
I cut bowl blanks frequently the average are 3-4 inches but some thinner and some general shop work nothing fancy
Lazyman
#5 posted 08-12-2018 01:10 PM
The rule of thumb is that you want at least 3 teeth in the wood at any given time so if you are cutting something less than 1” thick you should have a 4 or greater TPI blade in your saw but otherwise the 3 TPI blade will handle anything greater than than that, especially for rough work.
Karda
#6 posted 08-12-2018 05:37 PM
ok thanks
View OiBowyer's profile
OiBowyer
14 posts in 73 days
#7 posted 08-12-2018 07:33 PM
Hey Mike,
For cutting bowl blanks I prefer a 2 or 3 tpi resaw blade. The wider (deeper) blade deflects less in the wood when it changes density. For instance when cutting near a knot hole or defect. A narrower blade will allow for greater ease in cutting curves but will deflect more readily. Also I only cut straight-ish lines on the band saw.
-- Matt Bielenberg- turning student https://www.etsy.com/shop/Turning4SchoolMoney?ref=search_shop_redirect https://www.facebook.com/Turning-4-School-Money-213112446187330/?modal=admin_todo_tour
Karda
#8 posted 08-12-2018 09:38 PM
I have never used a 2 tooth before, are they more agressive.
View Nubsnstubs's profile
Nubsnstubs
1330 posts in 1811 days
#9 posted 08-12-2018 10:45 PM
- Karda
You betcha they are. WWing equipment doesn’t scare me much, but when I had a 2 tpi blade on my bandsaw, I was scared —-less when cutting blanks. Was never comfortable with it. I was a happy ww’er when it broke. 3 TPI blades will serve you well, and not put fear into your self. ................. Jerry (in Tucson)
