Wooden plane
« back to Hand Tools forum
Forum topic by sedcokid posted 07-24-2011 07:00 AM 1274 views 0 times favorited 11 replies Add to Favorites Watch
View sedcokid's profile
sedcokid
2732 posts in 3599 days
07-24-2011 07:00 AM
My father gave me this plane it measures 16” x 2 3/4” x 2 1/2”
As you can see it is in rough shape. My question is I don’t think that the blade is the right one.
Where can I get one that is?
Any help would be appreciated, I don’t know how to care for this neglected tool.
Thanks
The SedcoKid
-- Chuck Emery, Michigan,
11 replies so far
View Jim Jakosh's profile
Jim Jakosh
20489 posts in 3106 days
#1 posted 07-20-2011 04:19 AM
I don’t know much about them, but if the blade fits, I’d clean it up, sharpen it, and give it a go!!
The wood can be sanded and finished. That blade needs to have the rust removed. You could try some naval jelly on the steel parts and then sand and polish it. You’ll be surprised how good it can look…...........Jim
View RGtools's profile
RGtools
3372 posts in 2655 days
#2 posted 07-20-2011 04:31 AM
Take a look at the sole first and foremost. That is going to tell you where most of the problems are. (a pic here would be nice because it would allow me to help diagnose what you have to fix)
Get the rust off of the blade, in a case like this, electrolysis or Naval Jelly (or a similar rust removal product…I have yet to run across one that does not work). This will help you find out if you have a useable blade or if it will need replacement (that would be my bet based on what I see).
Wipe the plane down with a rag lightly soaked with butcher block oil this will help get rid of dirt without screwing up the patina.
Take a look at this blog, it’s not exhaustive but it has a basic walk-through on some points.
Then go check out Mafe's stuff…he trumps the heck out of me.
-- Make furniture that lasts as long as the tree - Ryan
View NJWiliam's profile
NJWiliam
32 posts in 2568 days
#3 posted 07-20-2011 08:58 PM
Wooden planes often shrink slightly making the blade not fit correctly. Is that why you think it isn’t the correct blade?
I would grind the blade slightly narrower so it fits, rather than adjust the cheeks of the plane.
Looks to be a fore plane, which is a great workhorse plane if you’re milling by hand.
View Don W's profile
Don W
18717 posts in 2568 days
#4 posted 07-20-2011 10:48 PM
to answer your question, woodcraft, lee valley and hock tools sells replacement blades for hand planes. Ebay is a good place as well. I agree with the others though, why do you think its the wrong blade, and even if it isn’t original, why are you thinking you need to replace it?
View WayneC's profile
WayneC
13754 posts in 4098 days
#5 posted 07-21-2011 12:42 AM
Do you have the screw that holds the chip breaker to the blade?
sedcokid
#6 posted 07-21-2011 02:30 AM
Hey All,
First of all thanks for your help regarding my plane.
RGTools thanks for the links very helpful.
WayneC, No I don’t have any screw, looks like it is just the wedge that holds the blade in place. Am I missing one?
Chuck aka ‘The SedcoKid’
WayneC
#7 posted 07-21-2011 02:31 AM
There should be a screw that holds the chipbreaker onto the blade…. The wedge secures both in the plane.
sedcokid
#8 posted 07-21-2011 02:36 AM
Nope… I sure don’t, Where can I get one?
WayneC
#9 posted 07-21-2011 02:44 AM
You might find this page interesting
http://www.handplane.com/47/parts-of-a-wooden-plane/
It depends on the size of the screw. Normally you could find one off of another parts plane, sometimes ebay or a used tool vendor.
You could check if one from an old stanley would work. Lots of sources for a replacement for Stanley planes.
http://www.stjamesbaytoolco.com/
Don W
#10 posted 07-21-2011 02:58 AM
together the blade and chip breaker goes similar to this.
sedcokid
#11 posted 07-21-2011 03:24 AM
Thanks for the help
