Resin over wood mold
Forum topic by willhime posted 08-09-2018 04:41 PM 360 views 0 times favorited 4 replies Add to Favorites Watch
View willhime's profile
willhime
126 posts in 1745 days
08-09-2018 04:41 PM
Topic tags/keywords: question jig resource tip trick router tablesaw finishing milling sanding shaping
I used melamine particle board to make the sides of a resin cast over a piece of fragile mesquite. I used a release spray, then caulked the outside edges to seal it. I’m trying to figure out how to get the sides off with cracking the solid resin areas. My initial idea was to flush trim route all the edges of the base then send it through the table saw with a high tooth plywood melamine blade but I don’t like the the thought of it cracking as I’m doing that and sending pieces flying around my shop and at me. Is there a good way to do this and are my fears justified?
-- Burn your fire for no witness
View Gene Howe's profile
Gene Howe
11079 posts in 3634 days
#1 posted 08-09-2018 05:02 PM
It should pop right off. Give it a whack.
View John Smith's profile
John Smith
1491 posts in 368 days
#2 posted 08-09-2018 05:31 PM
did you make a silicone rubber mold over the original mesquite wood ?
trying to understand your process.
-- I started out with nothing in life ~ and still have most of it left.
willhime
#3 posted 08-09-2018 07:12 PM
Put the piece on 1/4” plywood. Surrounded it with melamine particle board. Screwed the bottom to all of it and the melamine to each other. Caulked the outer lower seam. Sprayed mold release. Put the wood in it. Started filling it with resin till it capped.
John Smith
#4 posted 08-09-2018 07:50 PM
mold release on melamine should separate quite easily
I think I’ve got it now – - – you poured clear hard casting resin ??
if you can’t separate the melamine from the resin, the bandsaw may be
your only option if big hammers and pry bars don’t work. (and yes, the BS makes a mess).
I think that if you can get some thin pry bars in between the two, slow steady pressure should work.
also, separating the melamine plastic from the particle board with chisels is an option.
looking forward to seeing your finished project !!
