Danish oil finish
Forum topic by Hornnumb2 posted 08-09-2018 03:03 AM 439 views 0 times favorited 5 replies Add to Favorites Watch
View Hornnumb2's profile
Hornnumb2
38 posts in 970 days
08-09-2018 03:03 AM
Putting a Danish oil on a stained glass walnut frame that will be hanging in a window. Does it need a topcoat of some kind? Thanks Michael
5 replies so far
13630 posts in 3483 days
#1 posted 08-09-2018 03:15 AM
some spar varnish with uv inhibitor should help
after however many coats of danish you like has dried good
or it will not take a good top coat
otherwise the sun will just bake the danish
and you will have to keep re-adding as time goes on
with the spar varnish or some other top coat with uv inhibitor
it will still bake over time but will take longer between re-sanding and
re-applying
maybe if it is possible turn the frame and glass around once in a while
so both sides get sun and shade over time
this way you can forget a top coat
but will have to re-aplly danish from time to time
let it weather evenly by turning around occasionally
on most boats even with the best finnish outside
they still need to re-sand from time to time to keep the finish from degrading into a barn board look
Hornnumb2
#2 posted 08-12-2018 03:43 AM
I got 3 coats of spar on it, once it’s good and dry can I rub it with something to get it smooth?
#3 posted 08-12-2018 08:11 AM
a fine steel wool 0000 grit
if it looks somewhat scratchy
add a lightly thinned last coat
it should smooth out good
if it is ok after the steel wool
you should be good
View Lazyman's profile
Lazyman
2486 posts in 1529 days
#4 posted 08-12-2018 01:51 PM
Did you sand between coats? Usually the label will say whether that is recommended. What brand did you use?
View Gene Howe's profile
Gene Howe
10894 posts in 3570 days
#5 posted 08-12-2018 01:56 PM
As usual, Patron is correct. Ya need a good uv inhibiting top coat.
