Raised Panels: how tight should they fit?
Forum topic by GregD posted 675 days ago 1396 views 1 time favorited 16 replies Add to Favorites Watch
View GregD's profile
GregD
597 posts in 1307 days
675 days ago
Topic tags/keywords: question mahogany traditional
How tightly should a raised panel fit into the slots of the stiles and rails? What I have now requires firm pressure and maybe a bump or two of the palm to seat the panel into the slot of the frame, and it takes a firm grip to pull them apart. My caliper tells me that the thickness of my panels is a nearly 0.01” thicker than the slot opening. Too tight?
I am making an interior passage door – a 48” wide pocket door similar to a 6 panel frame-and-panel door but I designed it with 9 panels that are 9 3/4” wide. The door is 1 3/4” thick. Each opening in the frame will be filled with 2 panels, 13/16” thick, back-to-back. It would have been much simpler to get wide 8/4 stock and mill up solid 2-sided panels. Instead I resawed narrower 8/4 stock and made bookmatched panels that are single-sided. Many of my panel blanks were too thin to finish out at 7/8” thickness, so I ended up at 13/16” thickness.
In order to keep the surface of the panels flush with the surface of the frame the “slot” for the panels in the stiles and rails is a pair of 3/16” slots separated by 1/8”. I plan on using space balls in these slots.
Below are two of the finished panels (Waterlox – 2 coat of the standard stuff and 1 coat of gloss)
-- Greg D. -- the price of freedom is tolerance
16 replies so far
Beginningwoodworker
13225 posts in 1844 days
#1 posted 675 days ago
I would think it should fit lose in the rails and stiles. The rails and stiles are the parts that get glue, not the panel.
-- CJIII Future cabinetmaker
View Jack Barnhill's profile
Jack Barnhill
362 posts in 1537 days
#2 posted 675 days ago
The panels should fit into the rails and stiles without pressure but not so loose that they rattle.
-- Best regards, Jack -- I may not be good, but I'm slow -- www.BarnhillWoodworks.com
GregD
#3 posted 675 days ago
Just snug but not tight?
It doesn’t take much to go from a bit too tight to way too loose. In principle the spaceballs should keep the panels in place even if the fit is a bit loose.
View Loren's profile
4893 posts in 1818 days
#4 posted 675 days ago
I would go for looser than a friction fit. Sanding and waxing the
insides of the grooves can help the panel ease in.
You can use “space balls” to leave plenty of room for movement, yet
control rattling. I usually put a single nail through the top and bottom
of the panel at the center. This keeps the panel centered and
mostly controls rattle.
GregD
#5 posted 675 days ago
So on the sloppy side? I know how to do sloppy 8-)
The nails are in place of the spaceballs? I don’t see how I could get a nail in that wouldn’t show since both sides of the door are “good” sides.
View Bertha's profile
Bertha
13111 posts in 864 days
#6 posted 675 days ago
I’ve used pipe cleaners in place of space balls. Depending upon the thickness, I’ve shot a tiny brad into the center like Loren describes and just hidden it with a dab of putty. I made some panels too snug in my old kitchen. When the weather changed, I could literally hear them clicking and groaning. It was weird, but none of them exploded.
#7 posted 675 days ago
I sometimes shoot an air nail, but often I’ll drill a hole and put in
a little round-headed brass nail. Looks nice, and a brass nail head
can be set flush with the surface and sanded too – but it does
show to somebody looking close.
Bertha
#8 posted 675 days ago
^ I would actually prefer that look. Shows the thought. I may try this.
View Grandpa's profile
Grandpa
2381 posts in 846 days
#9 posted 675 days ago
you can make your own spaceballs using silicone caulk. make little dabs on waxed paper. Cut them with a box knife and you have them. Without clearance you will push the joints apart at the corners. I have always believed in the 1/16” rule. 1/16 in each direction. Loose fit and the space balls keep them from rattling.
View 000's profile
000
3352 posts in 787 days
#10 posted 675 days ago
they need a little wiggle room on the X and Y dimension and the fit in the groove should be just snug enough that they don’t rattle
-- When the moderator chooses sides, his site sucks.
View fussy's profile
fussy
964 posts in 1221 days
#11 posted 675 days ago
What Loren says. Too tight and something will break or warp. Space balls, little chunks of scrap foam, ear wax (just kidding) to take up the slop. Those qare too pretty to risk destroying them. Good work.
Steve
View Lee Barker's profile
Lee Barker
1889 posts in 1021 days
#12 posted 675 days ago
Here’s something that’s not intuitively obvious but affects your question: When finish is applied, it will not only make the tongue thicker, it will also make the slot narrower!
So to put it to words the best I can, the panel should fit in effortlessly or slightly easier, but definitely not snuggish.
Thanks for all the recipes for spaceballs!
Kindly,
View 000's profile
000
#13 posted 673 days ago
”ear wax (just kidding) ”
You better be kidding~!! Toe Cheese is the best for this. not ear wax. Ear Wax is for hand planes
Grandpa
#14 posted 673 days ago
These doors are simply beautiful. Do it right please…...
CR1 is correct. not too tight, not too loose but just right. I have a friend that was given a large chest with raised panel doors. It was nice but the panels fit tight. the doors were large so there was probably more expansion. This was a gift his mother-in-law had built for them. Evrytime they went home they carried a different door to have the corners repaired on the stiles and rails. It was a sad deal but the panels weren’t right. I think there should be a formula for larger or smaller doors.
GregD
#15 posted 673 days ago
Thanks for the comments.
I picked out two of the best panels just for some eye candy. Waterlox is great stuff. The grain that I ended up with was dumb luck. Never made bookmatched panels before. Never made any sort of frame-and-panel door before either, for that matter.
I’m planning on widening the groves for the panels so they aren’t too tight. If some panels then fit too loose I’ll put tape on the back side to snug those up. I’m also planning on using Spaceballs.
I followed the instructions that came with my Amana stile and rail bits: slots for the panels 1/2” deep, and panel dimensions 3/4” larger than the panel opening.
