Maintenance for G1023SL TS
Forum topic by Kevin posted 07-18-2011 03:39 AM 1009 views 0 times favorited 4 replies Add to Favorites Watch
View Kevin's profile
Kevin
462 posts in 3172 days
07-18-2011 03:39 AM
Topic tags/keywords: grizzly 1023sl table saw ts lubricating oil maintenance
I could probably find this online, but I figured my LJ friends here could provide me with more detailed instructions and photos maybe on the oiling/lubricating parts on the saw.
I keep the table waxed, leveled and keep the fence in good shape. I just need some photos or something on what to do about the lubricating on the parts.
Thanks,
Kevin
-- Williamsburg, KY
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2473 days
#1 posted 07-18-2011 04:12 AM
Sounds about right. I also check my blade angle sets and vacuum out any sawdust and spray my high/angle “screws” with dry lube.
View HorizontalMike's profile
HorizontalMike
7749 posts in 2881 days
#2 posted 07-18-2011 04:14 AM
This is for the G0690-691 which is basically a reworked/improved version of your G1023SL
Other than that, I use a LITTLE bit of WD-40 on the trunnion bushings (NOT the gears)/bearings. Too much and you just attract the sawdust and create wood putty. I actually wipe what I can reach after spraying, to minimize any oily film build-up.
Kevin
#3 posted 07-18-2011 05:26 AM
Thanks guys, exactly what I was looking for.
Kevin
-- Williamsburg, KY
View knotscott's profile
knotscott
7980 posts in 3343 days
#4 posted 07-18-2011 02:09 PM
No pics to prove it, but I brush the saw dust out of the elevation and tilt gears and spray them with white lithium grease or brush on some paste wax if I don’t have any lithium grease.
