Finishing Baltic Birch for use in high temperatures??
Forum topic by Popsnsons posted 07-17-2011 09:51 PM 1099 views 0 times favorited 2 replies Add to Favorites Watch
View Popsnsons's profile
Popsnsons
387 posts in 3010 days
07-17-2011 09:51 PM
Topic tags/keywords: finish finishing birch baltic birch protective coat lh question
I have a friend that is using Baltic Birch as a work top surface out in Cibola AZ. The work space is in a metal building and will be exposed to extreme temperatures. What would you recommend he use as a protective coat over the Baltic Birch?
-- Pops ~ In So Cal...
2 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2718 days
#1 posted 07-18-2011 03:22 AM
Depends on what you are trying to protect it from. BLO, poly, Spar will all stand up to Az. temps but not to sunlight. If it is a worktable, the poly or Spar will be subject to scratches which are hard to repair. He really doesnt need a “protective coat” over BB ply if it is just a work top surface.
Popsnsons
#2 posted 07-18-2011 05:41 AM
gfadvm,
Thank you for your input. I’ll pass it on. The work station will be indoors so no direct sun.
