Does heat affect Breakers?
Forum topic by Victor708 posted 07-17-2011 02:20 PM 11447 views 0 times favorited 9 replies Add to Favorites Watch
View Victor708's profile
44 posts in 3246 days
07-17-2011 02:20 PM
Topic tags/keywords: question circut breaker harbor freight dust collector electrical
Hey guys, this may seem strange but everyday when the outside temperatures hit ~100 (daily here in Texas) my Hf dust collector starts tripping the breaker. At first I thought it was a bad breaker but a new one didn’t fix the problem. My breaker box is on the back of my house and is exposed to the sum for most of the day. I was able to get a little more working time by lifting the cover on the breaker a little letting the air circulate a bit. In the evening when the temps drop the problem goes away. I haven’t had this problem in the past because until I air conditioned my garage shop a couple of weeks ago, it would get too hot to work in there long before it hit 100 outside. Has anyone else experienced this or am I crazy and have different issue?
-- "If a man is alone in the forrest with no woman to hear him. Is he still Wrong?"
9 replies so far
View Gregn's profile
1642 posts in 2916 days
#1 posted 07-17-2011 02:36 PM
I live in Oklahoma, so I have the similar weather situation here with the 100 degree temps. You have a different issue going on. Have you tried the DC on a different circuit? If its just the DC that has the problem I would check that if its still tripping breakers.
View bent's profile
311 posts in 3601 days
#2 posted 07-17-2011 03:07 PM
your circuit breakers contain a bimetallic strip that flexs with temperature change. current through the breaker creates heat which flexs the strip and causes the electrical connection to open. you’re not crazy, the high ambient temperature could be causing the breaker to trip without an excessive current.
View cutmantom's profile
401 posts in 2967 days
#3 posted 07-17-2011 03:26 PM
is the circuit able to handle the DC, a 15 amp breaker running a 15 amp tool is pushing the limit, the high temp outside may be all that is needed to push it over the limit, also is there something else on the same circuit
View superstretch's profile
1531 posts in 2626 days
#4 posted 07-18-2011 07:15 AM
The DC is in the air conditioned shop? If not, the heat could be causing it to run inefficiently, creating a high draw.
Also, you say the breaker is in the sun most of the day—Consider this: My grill was out today and the temp was ~90. Unfortunately, I leaned up against the grill and burned my arm (I hadn’t fired it up yet). The reason? The thermometer on the lid said 160. Your electronics are cooking inside a metal breaker box..
-- Dan, Rochester, NY
View David Grimes's profile
David Grimes
2078 posts in 2572 days
#5 posted 07-18-2011 07:35 AM
@ superstretch makes a great point. I have a 200 amp meter base / services disconnect that gets beat by the afternoon sun. Knowing that, I originally bought a white one. It is much cooler than the smaller medium gray colored ones for the heat and a/c units and the pool pump, etc. Painting your box would no doubt lower the heat gain of the box itself.
I have always heard that the Square D industrial breakers (QO, I believe… not the Homeline) have more heat resistant bakelite and the breaker itself due to the harsh industrial environments they are placed into. Again, Mr. Anal here spent twice as much for the QO’s in my main house breaker box (including GFCI breakers, about a dozen piggy backs, and now a handful of arc faults).
My outside stuff (again for heatpumps and pool) is GE, Murray, and Square D Homeline.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
#6 posted 07-18-2011 02:24 PM
Thanks for all the responses guys. Just a few particulars to answer some of the questions brought up. The dc is rated at 14 amps and was on a shared 15 amp circut. I know it was pushing the limits because I would loose have of my shop flourescents when I kicked it on. Once I started having problems I moved it to a dedicated line but the problem presisted. The dc is inside the a/c’d shop so the motor running under abnormally hot conditions is not an issue. With all the comments here I’ve come to the conclusion my problem is heat related. I think it may be time to consider the cost of having a 100 amp sub panel installed. Besides, I have four pieces of equipment including the a/c running on 220v. I’m growing tired of having to swap plugs to use some of them.
View Grandpa's profile
3259 posts in 2608 days
#7 posted 07-19-2011 12:20 AM
Heat is the enemy. heat also makes the breakers work. You are crowding the breaker anyway. You have a 14 amp motor running on a 15 amp breaker. You need to rewire and have a 20 amp breaker. Don’t just change the breaker unless you have 12 ga wire. Don’t make that mistake. Hgh temps cause more resistance so it is a vicious circle.
View peteg's profile
4251 posts in 2755 days
#8 posted 07-19-2011 12:41 AM
The Bi metalic activated breakers build up a memory to continual tripping resulting in say a 14a unit eventually tripping well below its nominated rating, I would suggest you are trying to protect your motor with a breaker running “on the redline”. protecting an inductive motor load with high start current is a different requirement to a basically resistive say heating/lighting load. Not sure about your set up but we used to used “motor rated” breakers when I was in the game many years ago, these are built specifically to withstand start up inductive loads, if you give your supplier the name plate ratings he will be able to supply you with the correct devise.
Hope this helps you. :)
View fussy's profile
980 posts in 2983 days
#9 posted 07-19-2011 02:34 AM
You answered your own question by opening the box cover to allow better air circulation. Try to vent it in some way, or shade the outside wall on which it’s mounted. Or move to Nome, Alaska.
