veneer on good one side panels
Forum topic by Ron Ramsey posted 07-16-2011 10:48 PM 967 views 0 times favorited 5 replies Add to Favorites Watch
View Ron Ramsey's profile
Ron Ramsey
36 posts in 2482 days
07-16-2011 10:48 PM
I’m planning a set of craftsman style cabinets for a kitchen I’m a building in our basement. I am using quarter sawn who’re oak as the main wood. I have some 1/4” (actually a little thinner, maybe 7/32?) Plywood. Eneer that I want to use for the door panels. I want to cut my own book matched veneer from some figured white oak and apply it to the side of the plywood that is not finished. Here’s my question.
Everything I’ve read is pretty clear that both sides pf the substrait need to be equally treated with veneer to avoid cupping or uneven flatness. Since one side of the plywood is already veneered from the manufacturer, will I have problems if I only glue my bookmatched pieces to one side?
Any suggestions will be appreciated.
Thanks, ron
-- Ron Ramsey, Rochester Hills,
5 replies so far
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3552 days
#1 posted 07-16-2011 10:56 PM
The experts say you should do both sides I have done this and also not done this and so far had no problems but my advice would be to stick to the experts read up on it under google there are lots of veneering/and plastic sheet coating tips there. Alistair
Ron Ramsey
#2 posted 07-16-2011 11:50 PM
I suppose the alternative may be to cut two pieces of panels from my white oak plywood and install them back to back. I would just have to cut a wider slot in the rails and styles.
View Loren's profile
10269 posts in 3615 days
#3 posted 07-17-2011 02:39 AM
Considering that your panel will be captured in grooves, I expect you’ll
be safe in this veneering situation. The safe play is to veneer both
sides.
That said, your panels may be cupped coming out of the press and
that may or may not cause you a problem.
Shaker doors are made with a 3/8” panel raised 1/8” on the back and
sometimes thicker and raised more – that gets the correct look and
feel. Doors made with 1/4” ply panels tend to feel kind of lightweight
when you swing them, like the cabinet doors in an RV. The extra
mass of a solid panel exudes the feel of quality.
Ron Ramsey
#4 posted 09-28-2011 05:17 PM
That’s good advice. Instead of veneer I thin I’ll resaw 3/8” panels like you suggested. Thanks
View EandS's profile
EandS
73 posts in 2429 days
#5 posted 09-29-2011 12:18 AM
I agree with Loren.
The frame and panel construction will stop any twisting or cupping from happening…or SHOULD.
-- ~ eandscarpentryandwoodworking.com ~
