Wood Hardeners
Forum topic by Taff posted 07-14-2011 08:02 PM 4423 views 0 times favorited 5 replies Add to Favorites Watch
View Taff's profile
Taff
29 posts in 3503 days
07-14-2011 08:02 PM
I am looking at wood hardeners of which I know very little. Many I see advertised are for marine use. Has anyone got experience in this field at all. I am concerned about the penetration of the hardener and whether it causes discoloration. I would be grateful for any advise you may have to offer.
Thank you
-- Glyn, North Carolina
5 replies so far
View shipwright's profile
shipwright
7966 posts in 2765 days
#1 posted 07-15-2011 02:18 AM
I’ve used this for years under it’s Industrial Formulators of Canada name. They were absorbed by System Three but it’s almost certainly the same old S1.
http://www.systemthree.com/store/pc/S-1-Sealer-c32.htm?gclid=COnmvP6HgqoCFRNhgwodAD5Nzg
It is basically epoxy and a very volatile solvent. It will go about anywhere that diesel will go and will harden punky rotting wood amazingly. It will also seal oily woods like yellow cedar to allow paint to adhere and can be used to seal plywood water tanks as it’s food safe when cured.
Great product.
Use a good respirator or air supply.
View Gene Howe's profile
Gene Howe
10367 posts in 3396 days
#2 posted 07-17-2011 04:36 PM
If the wood is punky or rotting, I use EndRot by System Three. Follow their instructions and IT WILL penetrate.
And it does get hard! Really hard!
As far as hardening new wood goes, I’d follow Paul’s (Shipwright) advise.
shipwright
#3 posted 07-17-2011 05:49 PM
cr1, Sorry you’ve had such poor luck with epoxies. You really should try some S1, it does penetrate and it does harden.
View Taff's profile
Taff
#4 posted 07-19-2011 01:21 PM
Thank you gentlemen I appreciate your comments, both pro and con. It seems S1 and Minwax are in for some testing – I will get back to you with the results.
View andysden's profile
andysden
45 posts in 2385 days
#5 posted 10-13-2011 01:39 AM
I used poly urathene on some Spalded and soft Maple pen blanks which had a lot of worm holes left them in for 24 hours I placed them in a large peanut butter jar filling the jar completly and sealing it. 6 blanks .75 x.75×6” absorbed about 1.25” of liquid in 24 hours turned it up side down let sit over night . Almost immeaditly the air bubbles started to appear . Let dry for a week then drilled 7 mil. for a pen The worm holes did not all fill in so I had to fill with saw dust and ca glue [crazy gule] . The pen looks great. Andysden
