Handheld Planers
Forum topic by Lakey posted 04-01-2008 02:16 PM 7214 views 0 times favorited 8 replies Add to Favorites Watch
View Lakey's profile
97 posts in 3702 days
04-01-2008 02:16 PM
Howdy Gang,
Do any of you have experience with handheld planers? This may be a stupid question, but can they be used to joint the face of a board prior to going through a stationary planer?
-- "No Board Left Behind"
8 replies so far
View DannyBoy's profile
521 posts in 3795 days
#1 posted 04-01-2008 03:12 PM
I have the Ryobi plug in and it is pretty good. The only thing I’ll caution you on is that they will eat a lot of wood really quick. Even on the lowest setting (which is technically ‘0’) it will eat through a board fast.
I’ve also tinkered with the display model of the Bosch one at HD. It feels real good in your hand, however (if I remember right) the forward handle is also the setting nob so you have to be careful with it.
Technique is everything when you are using one. In addition to keeping it at the lowest setting, make sure you put pressure on the front when you are first touching the board and then move that to the back as you complete you pass. Also, make sure you score the end of the board on both sides to avoid tear out. When tear out happens, it happens big…
~Danny Boy
-- He said wood...
View jcees's profile
1054 posts in 3729 days
#2 posted 04-01-2008 03:17 PM
First, do you know how to get a board F-L-A-T? I don’t mean to be pedantic, but are you familiar with winding sticks? The process of flattening a board? Is the board you’re wanting to flatten extra wide or otherwise unwieldy?
I guess what I’m getting at is that a hand held power planer will do the job and THEN SOME! In other words, this is not a tool with which you finesse anything and tearout can be a rabid problem. Mine has a helical cutter so that’s not a problem but most power planers have flat blades set square to the work and are heck on anything other than straight grain.
I’ve had much more luck processing a less than flat board easily with winding sticks and a combination of three hand planes—a #40 scrub, a #5 jack and then a #7 jointer. It takes only a little time and you’ll have the satisfaction of knowing that you can do the work WITHOUT electricity. The only caveat is you do need to know how to tune a hand plane and keep the blade sharp. I process all of my face wood thus—winding sticks and hand planes THEN I flip it over and run it through a 15” planer. Done and DONE.
Hope this helps. Good luck.
-- When one tugs at a single thing in nature, he finds it attached to the rest of the world. -- John Muir
View WoodRivWW's profile
32 posts in 3640 days
#3 posted 04-01-2008 04:13 PM
I agree with J.C.’s post. If you have a large, thick board with serious wind, you could probably knock down the high spots with a hand planer. It would save you some sweat before you brought in the hand planes. I have a Craftsman that I use mainly for planing the edges of old doors I’ve picked up that I’m resizing to fit in my old house renovation. Hand planes on this kind of grunt work would be pretty labor intensive.
-- Hailey, ID
View 8iowa's profile
1569 posts in 3691 days
#4 posted 04-01-2008 04:52 PM
I agree with JC. I only have a #4 smoothing, and a #5 jack plane, but it does not take a great deal of time to prep flatten a board for a trip through your planer. Unfortunately, most of the hand planes on the market today require a fair amount of work and “tuning” before you can use them. The exceptions are the planes made by Lie-Nielson (USA) and Clifton (UK). These planes are more expensive, but are ready to go out of the box.
I use waterstones and a Veritas MK II honing gauge to sharpen my plane irons and chisels.
View tenontim's profile
2131 posts in 3674 days
#5 posted 04-01-2008 05:09 PM
Lakey, if you know the basics of flattening a board, the hand held planers will work fine. I like the Bosch 1594. I haven’t bought one for myself yet, but have tried it. I’m still using hand planes too. The power one will just use less muscle. If you have the room, build yourself a jig for flattening one side and running it through your planer. GaryK posted a good design.
27251 posts in 3752 days
#6 posted 04-01-2008 05:11 PM
These really don’t have enough bed length to do more than planing door edges. They are essentially a power version of a block plane. I have tried using it to flatten stock wider than my jointer could handle but essentially it just gouged the wood.
To be honest with you I would not recommend trying to edge or face joint a board with an electric hand planer. You will have better luck with a set of hand planes.
#7 posted 04-01-2008 06:30 PM
Thanks, everyone. I do indeed know how to flatten boards with hand tools – your responses definitely answered my question – appreciate it.
View GaryK's profile
10262 posts in 3918 days
#8 posted 04-01-2008 09:21 PM
They would be good for taking off the high spots to get is close for machine planing.
