motot 1 hp 3450
Forum topic by joez posted 07-13-2011 02:16 AM 1107 views 0 times favorited 6 replies Add to Favorites Watch
View joez's profile
joez
120 posts in 2777 days
07-13-2011 02:16 AM
Topic tags/keywords: motor sander grinder
what kind of pulley situation would be best suited for a home made bench grinder to grind plane blades and wood with a that has 1 hp 3450 rate motor.
No obnoxious opinions need to be expressed thank you.
View PurpLev's profile
PurpLev
8534 posts in 3523 days
#1 posted 07-13-2011 02:32 AM
if you want this for high speed grinding then something between 1-2 / 1-1 setup would give you a ~1500rpm-3400rpm which is comparable to high speed grinders. I actually have a variable speed grinder and those 2 speeds are the low and high on the dial.
View MedicKen's profile
MedicKen
1610 posts in 3337 days
#2 posted 07-13-2011 03:05 AM
You can add an arbor directly to the shaft of the motor for the grinding wheel. I have one on an old Delco motor now and it works just fine. You can find one here or any good industrial supply should have htem locally. If you are wanting to build a stand and mount the motor and use pullies a calculator can be found here
View Bertha's profile
Bertha
13495 posts in 2567 days
#3 posted 07-13-2011 04:20 PM
^confused, too.
View joez's profile
joez
#4 posted 07-13-2011 07:26 PM
View joez's profile
joez
#5 posted 07-13-2011 07:27 PM
dont be confused there are people here who are very rude!
View HerbC's profile
HerbC
1709 posts in 2734 days
#6 posted 07-13-2011 11:19 PM
Joez said “dont be confused there are people here who are very rude!”
Yes, there are…
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
