Easy glue question
Forum topic by tyskkvinna posted 07-12-2011 03:40 PM 2237 views 0 times favorited 19 replies Add to Favorites Watch
View tyskkvinna's profile
tyskkvinna
1310 posts in 3010 days
07-12-2011 03:40 PM
Topic tags/keywords: glue
I am looking for a glue that I can use to adhere magnets (little round disk type) onto wood and plastic. (Acrylic, if it matters.)
I did my testing with some of that low-expand gorilla glue and it still expanded a lot (but the magnet sure is not going anywhere! :) ) and yesterday I did some tests on plastic with generic CA, which sure stuck it good but it also kind of went everywhere, which wouldn’t have been noticeable on wood but on the acrylic you can see it clearly.
So I’m thinking a gel glue would be good? Any brand of gel CA work the best in y’all’s opinion? I need A LOT of whatever I use, so I would prefer to buy it in slightly larger containers than those teensy tubes they sell at Hobby Lobby. (And I don’t mind buying online!)
Thanks, guys!
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
19 replies so far
View David Kirtley's profile
David Kirtley
1286 posts in 3022 days
#1 posted 07-12-2011 03:46 PM
You might also consider System Three Gel Magic. It’s a two part epoxy. Really nice to work with.
View lew's profile
lew
12102 posts in 3780 days
#2 posted 07-12-2011 04:15 PM
Maybe here;
http://www.woodturnerscatalog.com/store/AdhesivesInstantGlueHotStuffSuperT_hotstuffsupert?Args==
View Bearpie's profile
Bearpie
2601 posts in 3042 days
#3 posted 07-12-2011 04:15 PM
Lis, I prefer the titebond brand. There may be better brands out there but I haven’t run across them yet. They come in 2 and 4 oz containers. I bought the 4 oz container thinking I would save $ and time cause I use a lot of it too, BIG mistake! The tip hole is slightly larger than the 2 oz size and you usually get more than you want out and is harder to control the amount you use. Also the tip being larger leaves a slight amount on the tip as spillage and when you put the cap on it sticks to the cap and requires periodic cleaning and that tends to ruin the threads on the cap and I usually waste about half of the 4 oz size. The 2 oz is much easier to control and I get much less waste. It comes in 3 forms thick, medium, and thin.
As for the 2 part epoxy, I have used it once and found it time consuming and messy. It may be that I did not use it right or have enough knowledge in it’s usage. I do know that it has good properties if used appropriately.
Good luck and nice seeing your icon back on LJ.
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
View crank49's profile
crank49
4032 posts in 2995 days
#4 posted 07-12-2011 04:46 PM
Liz,
I have not had that much luck with CA used to bond polished metal. Seems to come apart after a while. I will agree with Bearpie about the Titebond brand. It works well.
I have had much better success with epoxy. A little lacquer thinner is good to de-grease surfaces before bonding and works for cleanup as well. I like the System 3 products, but that is the only professional brand I have tried; the rest were what ever they had at the Walmart or Home Depot the day I was shopping. They all lasted longer and gave a more powerful bond than any other type of glue I have tried on polished metal.
View BobTheFish's profile
BobTheFish
361 posts in 2576 days
#5 posted 07-12-2011 04:53 PM
Bearpie, What I do with some glues is simply transfer some of the glue I buy in bulk to smaller used containers.
for the original post, I’d second the idea of epoxies or a CA glue. Also remember, gels are nice, but they rarely penetrate as well as something more…. “runny”.
View richgreer's profile
richgreer
4541 posts in 3099 days
#6 posted 07-12-2011 05:22 PM
CA glue comes in different viscosities – thin, medium and thick. I use the thick CA glue when gluing magnets.
If I am working with round magnets, I usually drill a shallow hole the size of the magnet and glue the magnet into the hole.
View Nomad62's profile
Nomad62
726 posts in 2983 days
#7 posted 07-12-2011 05:23 PM
You might give hot glue sticks a try, not sure how it would turn out but it is clear..
View Bertha's profile
Bertha
13529 posts in 2718 days
#8 posted 07-12-2011 05:25 PM
I was thinking gluestick myself. They have some high bonding varieties out there now & you can buy sticks by the ton if you like.
View AaronK's profile
AaronK
1506 posts in 3489 days
#9 posted 07-12-2011 05:40 PM
yeah, hot glue is surprisingly strong. I’d suggest that or epoxy.
Bearpie
#10 posted 07-12-2011 06:01 PM
Bobthefish, I have tried buying the larger container and transferring into the smaller container but the problem I had with that is the smaller container is good for only one transfer before the threads are “ruined” (at least for me) and I would still have to buy another small container and use that up and use the second half of the larger container. Much simpler to just use the 2 oz container.
On another note; I used the thick glue to glue a board to an rectangular aluminum tube that I use for re-sawing to prevent the aluminum transferring grey marks to the wood I am cutting due to vibrations of the saw. It worked well till I went on vacation for a week and came back to find the board laying on the floor, I had to drill and screw the board to the aluminum tube. Seems the glue did not adhere well to the aluminum as there were very little glue on it and most of it was on the wood.
View HerbC's profile
HerbC
1763 posts in 2884 days
#11 posted 07-12-2011 06:03 PM
Lis,
Here’s another source for CA glues that has a large variety of brands, types and sizes…
HobbyLinc
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
tyskkvinna
#12 posted 07-12-2011 06:12 PM
Thanks everybody! :) I will look into the different choices suggested here and see what works for me. I am hesitant to try hot glue because I use low-melt glue in the shop everyday (to hold down pieces while I cut them on the CNC) and I can totally see myself mixing up the two, even if I dedicate two different glue guns to the task. (I’m talented like that)
I generally do them in big batches, so some of these choices look awesome!
View jayman7's profile
jayman7
218 posts in 3530 days
#13 posted 07-12-2011 06:12 PM
I usually scuff up the magnets and use 5 minute epoxy and had no problems thus far.
View Jeff's profile
Jeff
439 posts in 3219 days
#14 posted 07-12-2011 06:21 PM
A little dab of silicone sticks almost anything to anything else.
View Steven Davis's profile
Steven Davis
118 posts in 2939 days
#15 posted 07-12-2011 07:09 PM
I’ve read that rare earth magnets are coated with something (I think they are a bit brittle), so scuff them up, as noted previously, to give the coating some texture for the glue to bond with….
and when in doubt, use epoxy. (I understand that once textured, CA should work fine)
-- Steven Davis - see me at http://www.free2secure.com/
