how to securely pin a half-lap joint?
Forum topic by rwde posted 07-11-2011 08:46 PM 4269 views 0 times favorited 6 replies Add to Favorites Watch
View rwde's profile
rwde
42 posts in 3521 days
07-11-2011 08:46 PM
I am making an arts & crafts style picture frame with half-lap joints at the corners. I wanted to pin the joint, so I clamped sides A and B, marked and drilled a nice hole – and wouldn’t you know it, the sides must have slipped a little while drilling. When I unclamped them and inserted the pin, there’s now an unsightly gap. So – for next time, should I glue the 2 halves together, clamp & dry, and then drill? How do the pros do it? Thanks.
Rob
16274 posts in 4182 days
#1 posted 07-11-2011 08:49 PM
I don’t know about the “pros” , but I would definitely glue first, and put the pin in later. I can’t see any advantage to doing it the other way.
View TheDane's profile
TheDane
5399 posts in 3626 days
#2 posted 07-11-2011 09:18 PM
Second Charlie’s comment. The door on my router bit cabinet was glued first, then drilled/pinned.
Click for details
—Gerry
View AaronK's profile
AaronK
1506 posts in 3428 days
#3 posted 07-11-2011 09:33 PM
yeah, i’ve had the same problem. the solution was as these guys say: glue first, let it dry enough, then pin it.
View Bertha's profile
Bertha
13521 posts in 2656 days
#4 posted 07-11-2011 09:34 PM
Is it “off” in the direction so you can drawbore it? If so, you might have the strongest joint around. Plus, you might be able to justify some cool drawbores. ;)
View rwde's profile
rwde
#5 posted 07-12-2011 09:31 PM
Learn something every time. And now I get to look into drawbore joints and square pins. Thanks for the comments.
View WayneC's profile
WayneC
13753 posts in 4061 days
#6 posted 07-13-2011 02:47 AM
Think there is a Chris Schwarz blog entry on this as well as a video from him on how to do this…
Update – Link to Article
http://www.wkfinetools.com/contrib/cSchwarz/z_art/drawBoring/drawBoring4.asp
Link to video
http://www.youtube.com/watch?v=yAkWMHDKB-E&feature=related
http://www.youtube.com/watch?v=nG1jNQzwvQ8&feature=related
DVD with most info
http://www.craftsmanstudio.com/html_p/AV10-D.htm
