Any luck converting a bench plane or coffin smoother into a scrub plane?
Forum topic by Brett posted 07-11-2011 08:06 PM 1667 views 0 times favorited 7 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2650 days
07-11-2011 08:06 PM
Has anyone had much success converting a bench plane (like a #4 Stanley Bailey) or a coffin smoother into a scrub plane? How well do they work compared to purpose-made scrub planes like those built by Stanley, Veritas, LN, or Emmerich?
-- More tools, fewer machines.
7 replies so far
View TheDane's profile
TheDane
5401 posts in 3630 days
#1 posted 07-11-2011 08:42 PM
I have heard of guys converting a #5 jack plane into a scrub … as I recall, all they did was camber both sides of the iron. Never tried it, though.
—Gerry
View Bertha's profile
Bertha
13521 posts in 2660 days
#2 posted 07-11-2011 09:39 PM
Sure! We’ve been talking about this recently, I think in “handplanes of your dreams”. Mads, I think, had the best cambering jig. I haven’t had much success properly cambering blades, even in my #40. The guys are putting gentle chamfers on #5’s with great success, apparently. Check with Wayne and Dan; I think they’ve both done it.
View canadianchips's profile
canadianchips
2600 posts in 2964 days
#3 posted 07-11-2011 10:07 PM
I converted this “No name” 3 years ago. It works well, I did put a larger handle on it, my hands were to large for the original handle. No chipbreaker, easy to convert.
Bertha
#4 posted 07-11-2011 10:39 PM
Chips, I think I’ve got this same little no name. I might camber the blade after seeing yours:)
View Loren's profile
10269 posts in 3615 days
#5 posted 07-11-2011 11:42 PM
Scrub planes are usually narrower than standard bench planes. The
narrower cut helps you cut deeper with greater ease.
I have a no-name scrub plane myself, similar to the one above. I don’t
recall if the iron was cambered when I got it, but it has only a rudimentary,
non-adjustable frog, no chip-breaker, and the same sort of lever cap
as the plane above. I think these were common – and you could
use them as a scrub or carpentry plane easily enough.
View WayneC's profile
WayneC
13753 posts in 4064 days
#6 posted 07-12-2011 12:29 AM
My recommendation is a #5 or #6 with a cambered blade. Also you could use a transitional jack plane for this type of work. Some folks are anti scrub plane from the perspective of it taking too rough of a cut…
#7 posted 07-12-2011 01:16 AM
I’m no Luddite – when I need to scrub a big slab I use a screaming hand-held
planer. The skill is the same actually, it’s really about your eye and sense
of what flat is and feeling the balance of the tool. I’ve cambered blades
on electric planers too.
I flattened a lot of boards by hand when I was starting out. I got in real
good shape, but I got over the romantic idealism about it. Like Bob Dylan,
I may have lost my soul when I went electric, but it was so much easier
I never looked back.
