What's your favorite shelf pin drilling method?
Forum topic by Loren posted 707 days ago 3096 views 0 times favorited 37 replies Add to Favorites Watch
View Loren's profile
5023 posts in 1844 days
707 days ago
I’ve used a few different jigs over the years. I’ve never been blown
away at the speed of any of them.
I guess without having a CNC or a line boring machine, most of us would
be using a drill or a plunge router to make the holes.
What are people using here?
37 replies so far
View helluvawreck's profile
helluvawreck
10889 posts in 1062 days
#1 posted 707 days ago
Loren, we use to build 32mm cabinets for a good number of years and we had automatic and semiautomatic line drilling machines. However, one of my jobs was to make the samples for new cases. To a certain extent I could use the machines for fitting holes but sometimes I just used a drill press or hand drill. I always used hand drills to drill the shelf support holes unless a machine was already set up. My jig was just a simple aluminum drill guide that keyed off of the edge (I made it on a milling machine) and I used a drill stop on the drill for a depth gage. I could make a sample pretty fast with simple tools. It was always a pain in the ass to make samples because we were always needing them and I was always needed elsewhere so I was always rushed.
We would have been better off having a small sample dept with one or two small line drills dedicated to that department and not for production. However, Our business was always growing and it always seemed we had to throw the money at making the production more efficient.
View Viktor's profile
Viktor
440 posts in 1614 days
#2 posted 707 days ago
Template: a block of wood with several carefully measured and drilled holes in a row at desired spacing. Usually offset from the edge the same distance as in the shelf for easier lineup. It’s slow, but I’m not doing it for living.
View DrDirt's profile
DrDirt
1719 posts in 1938 days
#3 posted 707 days ago
Drill Press – with a piece of peg board double stick taped to it.
The drill press keeps me from messing up the depth and always gets the pins perpindicular to the surface.
-- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison
View Luke's profile
Luke
204 posts in 883 days
#4 posted 707 days ago
hardboard template with a 3/8” spaced holes, and a plunge router with 1/4” downward spiral bit and 3/8” guide bushing.
My last shelf pin jig I dadoed a 3/8” grove aligned on top of the holes just shallow enough to keep the guide busing in the track so all I need to do is slide the router an it will drop in the holes, then plunge with the 1/4” downward spiral bit and perfect 90degree holes that are exactly the same depth, and zero chip out even on Melamine.
View Bertha's profile
Bertha
12906 posts in 889 days
#5 posted 707 days ago
I always just used 1/2” ply with an edge register and bit stop. As a hobbiest, I could never justify the commercial jigs. I imagined making one out of clear acrylic but it never materialized. Good luck!
View 8iowa's profile
8iowa
1447 posts in 1957 days
#6 posted 707 days ago
I drill the holes in the sides before assembly of the case. First, I use a tape measure to mark the spacing 1” apart down the length of the side, then taking a combo square I mark the hole centers 2” in from front and rear.
Using the Shopsmith in drill press mode, I set the fence for the 2” spacing and “eyeball” each drilled hole, setting the stop so that I don’t drill all the way through. For long boards I use roller bearing stands to support the board on each end.
I find this method to be surprisingly accurate and quick.
View Richard's profile
Richard
501 posts in 886 days
#7 posted 707 days ago
There are a lot of commercial jigs available for people that do a lot of shelf units, but for the few times I have needed to do them a peice of pegboard nailed to a 1” x 3/4” scrap whatever length I need and use a hand drill with a depth stop on the bit seems to work.
View canadianchips's profile
canadianchips
1780 posts in 1193 days
#8 posted 707 days ago
I use a template made from 1/4” puck board and a hand drill with a depth stop on the bit. This works for the few holes I make each year.
View stnich's profile
stnich
91 posts in 1120 days
#9 posted 706 days ago
Peg board with a Vix Bit. Easy to use just make sure that you keep left and right in mind as well as top and bottom.
View TrBlu's profile
TrBlu
334 posts in 821 days
#10 posted 706 days ago
I use a piece of peg board for a guide and a handheld power drill.
-- The more I work with wood the more I recognize only God can make something as beautiful as a tree. I hope my humble attempts at this craft do justice by His masterpiece. -- Tim
View waho6o9's profile
waho6o9
3058 posts in 773 days
#11 posted 706 days ago
Festool lr32 (?) works great.
View moment's profile
moment
1627 posts in 877 days
#12 posted 706 days ago
16 dremels ganged together on a long narrow plunge type base .
Produces 64 holes in under 7 seconds . Simple and faster than a CNC when
you need to drill a few hundred shelf pin holes.
Not practical for one-offs .
Did I win ? Where is vonhagen ?
View David Grimes's profile
David Grimes
2065 posts in 835 days
#13 posted 705 days ago
Browning Challenger .22 pistol with CCI Stinger .22 LR (not hollow point) at 10 feet with laser sight.
Make sure that SWSOGM (don’t EVEN ask) does not sneak up on you.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Howie's profile
Howie
2424 posts in 1119 days
#14 posted 700 days ago
Rockler jig. Works good.
-- Don't rollerskate in a buffalo herd
View teejk's profile
teejk
986 posts in 880 days
#15 posted 699 days ago
I stick with Norm’s simply plywood jig…plunge router with guide bushing. with time and usage the guide bushing holes loosen up a tad and a row of holes goes quickly
http://s1217.photobucket.com/albums/dd385/Teejk/wood%20stuff/?action=view&current=0719011246.jpg
showing 1 through 15 of 37 replies
