Source/Info re: Epoxy
Forum topic by gfadvm posted 07-11-2011 05:50 PM 1567 views 1 time favorited 12 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2924 days
07-11-2011 05:50 PM
Topic tags/keywords: question resource
I want to do an end grain mesquite slab small table and fill the cracks with epoxy,glass,etc like I’ve seen others do. I’ve never used any kind of epoxy so am starting from scratch. Do you use 2 part stuff from HD or what? Buy it in qua rts,pints, or ? Any tips/pitfalls to avoid would be welcome. Thanks. ps I’d rather buy it locally rather than ordering if possible.
12 replies so far
View nailbanger2's profile
nailbanger2
1041 posts in 3378 days
#1 posted 07-11-2011 06:08 PM
I just recently picked up a two part system made by Loctite sold at the orange box. Strong bond, but very yellow and seemed to bubble quite a bit, leaving air pockets. I have heard (or read) positive reviews for West systems epoxy, but I have never used it.
-- Wish I were Norm's Nephew
View David Kirtley's profile
David Kirtley
1286 posts in 3232 days
#2 posted 07-11-2011 10:58 PM
You want something that will be slow curing. Depends on how big before I could guess at how much. More likely at least into quarts for a table. They have some that is pretty liquid for self leveling but I don’t think it is that much of an improvement. You want thicker to fill gaps.
You will more than likely have to fill the gaps in layers and build up. (Along with making dams to hold it in.) Until you are used to it, mix the epoxy in SMALL batches. No more than 2 ounces total. The larger the batch, the faster it kicks off. Besides wasting it, it gets REALLY hot. Spreading it out in a thinner layer will let it not kick off so fast (I use styrofoam plates and bowls) As long as you are within a day (They say three days, but I don’t trust that much) each layer will still chemically bond with the previous layer without sanding. You can really start the next layer when it goes to the gel state.
I like System Three epoxy but the other brands are fine. Higher quality epoxy is less yellow than the cheap stuff. If you are going to have it outside, it will need to be varnished to protect the epoxy from UV light.
Once you get used to it, epoxy is really nice to work with and more forgiving than many types of glue. Just remember, you can always sand it off.
View Gene Howe's profile
Gene Howe
11135 posts in 3663 days
#3 posted 07-12-2011 12:09 AM
West Systems, for one, has a really neat dispensing system that’s nearly goof proof. It’s a slow setting formula. They sell thickeners if you need them. (colloidal silica)
No place anywhere near me sells it so I order from Jamestown Distributors.
Gene Howe
#4 posted 07-12-2011 12:47 AM
Hey Doc,
Just went to your home page and saw you were from Jenks, OK. You can find West Systems stuff at
West Marine-528
4317-A S Sheridan Rd, Tulsa, OK, USA
918-665-2101
gfadvm
#5 posted 07-12-2011 03:20 AM
Thanks for the input guys. Good find on the West locally. cr1 dont know, never tried it, but looks really cool so I gotta try!
View grizzman's profile
grizzman
7836 posts in 3538 days
#6 posted 07-12-2011 04:31 AM
doc ive tried some epoxy along the way and have used it for a few inlay situations i did…it worked so good i will do it again..sometimes i will get the epoxy mixed and then i have stirred in some red cedar dust and poured it over a contrasting wood..i cna show you what i did from the project i have in my gallery…i think you will like it….grizz
-- GRIZZMAN ...[''''']
grizzman
#7 posted 07-12-2011 04:38 AM
this is a tray i made for my sister, i cut the flowers on the scroll saw and then insert them into the cut out i made with the router, i then took the epoxy with the red cedar saw dust mixed in and poured it over the wooden flower…after it hardened i sanded it and it came out beautiful…just a neat way to do this …it worked for me anyway…just a idea for ya…grizz
gfadvm
#8 posted 07-12-2011 04:51 AM
Grizz – You’re right, I Like it a lot. Does the addition of the sawdust alter the cure time/ workability appreciably?
grizzman
#9 posted 07-12-2011 04:59 AM
no it didnt alter one thing…since they were a small area i did it with a 5 minute epoxy..but depending on how fast i think i can do a project..i would use something that cured slower if it was medium to large in size…i just did another one that im posting in the morning…i free hand cut with the router a fancy letter into the top of a box i made..its the letter R…and i mixes the saw dust from curly maple..it turned out pretty good…but next time i will use a softer white wood to mix in, as is gets into a finer dust then does a hardwood…but ill post it tomorrow and you can see it…good luck on your adventure…grizz
View Jim Finn's profile
Jim Finn
2688 posts in 3156 days
#10 posted 07-12-2011 09:27 PM
I have used a product called “Z-Poxy” I got at a local hobby shop and mixed powdered blue chalk (From the dollar store) with it, to fill in voids and cracks in Mesquite. Worked well for me. And the blue color looked nice in Mesquite.
-- No PHD just a DD214 Website> craftingcouple.com
View Steven H's profile
Steven H
1117 posts in 3294 days
#11 posted 07-12-2011 09:59 PM
The stuff is expensive nowdays for $60 for 2 pint of epoxy filler.
View tblank's profile
tblank
74 posts in 3204 days
#12 posted 07-18-2011 01:11 AM
Resin Research makes surfboard specific epoxy that is clear, will NOT yellow and is UV resistant. Most other epoxies will yellow in time.
