Strops. What is best (alone or in comb.): Leather, Canvass, Linen, Silk, or Salvaged Seat Belt ?
« back to Hand Tools forum
Forum topic by David Grimes posted 07-11-2011 08:54 AM 2267 views 0 times favorited 5 replies Add to Favorites Watch
View David Grimes's profile
David Grimes
2078 posts in 2759 days
07-11-2011 08:54 AM
Topic tags/keywords: sharpening strop
If stropping is part of your sharpening regimen, please tell me what you use and how you use it. Thanks.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
5 replies so far
View Loren's profile
10477 posts in 3767 days
#1 posted 07-11-2011 09:09 AM
I mostly use a soft linen wheel charged with green rouge – and it
does take a light touch and knowing when to stop, lest the edge
get rounded over.
When done right though the edges are actually razor sharp and
I often have bald spots on my arm to prove it.
For the insides of more acute carving tools I am not convinced
a soft buff is effective and in any case something coarser is needed
here and there. Plane irons and chisels get pretty beat up but
fortunately they are straight and workable with whatever stone
is available. I have tools in two states, but between the two
my only common sharpening gear is the Makita wet wheel grinder
with a 1000 grit wheel. It a matter of seconds it corrects many
edge problems and a couple of touches on the buffing wheel
puts the tool back to work.
It may be unscientific, but my intuition and experience tells me
that an edge honed on a fine, flat waterstone outlasts one
polished on a buffing wheel. The wheel is lots faster though.
View funchuck's profile
funchuck
119 posts in 3177 days
#2 posted 07-11-2011 12:23 PM
I use leather. First I take some strokes on the rough side with green crayon, then, I take 5 strokes on the smooth side (with nothing added). I use the lee valley leather strop that is glued to wood. It’s a bit on the small side, so I plan to get a bigger one.
-- Charles from California
View waho6o9's profile
waho6o9
8362 posts in 2696 days
#3 posted 07-13-2011 05:11 AM
Make your own. Get some leather, spray 3m adhesive, flatten it. Keep it where you work and strop every so often. You’ll be amazed at the difference of a constantly honed chisel. Makes work a pleasure.
David Grimes
#4 posted 07-13-2011 05:31 AM
But I like cows
View jimp's profile
jimp
208 posts in 3880 days
#5 posted 07-13-2011 06:15 AM
leather with Herb’s Yellowstone stropping compound. It works awesome!
-- - Jim, Carroll, OH
