Spraying Spar Varnish
Forum topic by slick1 posted 07-10-2011 05:58 PM 11902 views 0 times favorited 14 replies Add to Favorites Watch
View slick1's profile
slick1
19 posts in 2840 days
07-10-2011 05:58 PM
Has anyone had any experience spraying marine spar varnish with a Critter spray gun?
I have twenty newly-made adirondack chairs, stained & ready. I sprayed the stain on ok with the Critter gun; but I have found nothing about spraying spar varish with it.
Do I need to thin the varnish, etc? Thanks!
-- - - - Rod , Lloydminster, Saskatchewan, Canada
14 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2565 days
#1 posted 07-10-2011 10:21 PM
I spray undiluted Spar with my cheapo Home Depot spray gun and it works great. Dont know about a “critter” but try it on scrap or cardboard and let us know how it goes.
View wisno's profile
wisno
88 posts in 2886 days
#2 posted 07-10-2011 11:48 PM
Yes, basically your can spray he marine spar varnish.
Thin the varnish little bit to fulfill the viscosity requirement according to the spray gun.
Thanks
god luck
-- http://www.wisnofurniturefinishing.com/
View Arthouse's profile
Arthouse
250 posts in 2525 days
#3 posted 07-11-2011 02:45 AM
spar varnish is not recomended to be sprayed because you have to thin it so much it looses it consitisancy . The solids don’t stay together and usually you have a huge runny mess. It brushes better anyway.
-- "The hand is the cutting edge of the mind but the wind and sun are the healing factors of the heart
gfadvm
#4 posted 07-11-2011 03:17 AM
Arthouse – With all due respect, I couldnt disagree more. I spray a LOT of MinWax Spar with really good results using a HD cheapo sprayer and undiluted Spar. Check out my projects for examples. Not trying to start a fuss here.
View Steven H's profile
Steven H
1117 posts in 2935 days
#5 posted 07-11-2011 05:00 AM
Maybe you should go buy the spray can version LOL
slick1
#6 posted 07-12-2011 03:15 AM
Well, I guess I will try spraying it on some scrap first and see how it goes.
1st with no thinner & then with thinner if I have too. Brushing is not an option here; with 20 chairs to do & 3-4 coats each. I’d be old and grey by the time I’m done…LOL.
Thanks for all your input gang!!!
View Carl Webster's profile
Carl Webster
82 posts in 2673 days
#7 posted 07-12-2011 04:11 AM
I would recommend you thin spar varnish with one part mineral spirits to every two parts varnish. Spray light coats to avoid runs.
-- Carl in SC
View JJinAK's profile
JJinAK
1 post in 2385 days
#8 posted 07-12-2011 08:51 AM
At the risk of going “off topic” a bit, what do you all think the minimum air compressor capacity would be for pushing spar through a spray gun? Thanks.
Steven H
#9 posted 07-12-2011 05:08 PM
You would have to keep tuning it until it spray efficient.
slick1
#10 posted 07-15-2011 02:39 AM
OK !! Looking good!
Just finished spraying first coat of Spar Varnish on the chairs.
Had to practice lots on scrap wood before doing chairs to get air pressure, mix ratio of mineral spirits & spar varnish & distance from wood.
First, a friend of mine who paints auto’s for a living recommended & let me use his old Devilbiss JGA-A-502-30X spray gun. (30X being the cap and needle size), which handles reduced varnish just fine. This gun will atomize the spar varnish into just the right particles for the perfect finish. On my Porter Cable pancake compressor, I set the air pressure at the gun at 50 pounds. Also, make sure you use an airline filter for moisture.
I opened up the material control valve almost all the way and adjusted the fan width to a 4” width at about 10” – 12” away & 50% overlap each spray pass. Clean tip end with clean rag after 3-4 passes or else varnish will build-up on tip causing spray pattern to sputter.
Mix Ratio: First, mix an equal amount of Naphtha and mineral spirits (50-50) together. I added in the naphtha, which is a much faster evaporating solvent than mineral spirits. (50% Naphtha & 50% Mineral Spirits is roughly, what lighter fluid is). Careful, you are working with big-time flammables here!
Second, mix ONE part of the Naphtha/Mineral spirits mix to THREE parts spar varnish.
The key here, being to get a smooth, level, and even coat applied, with no runs…that is the trick, isn’t it! If you reduce (or thin) the coating too much, you will not get enough of a dry film left on the surface to cover and fill.
Save your lungs and wear a cartridge-style, organic respirator. Wear old long sleeves shirt, hat, and a pair of pants you don’t mind ruining. Better yet, buy a cheap Tyvek suit for a few bucks. Use disposable surgical gloves. I always have a box of these in my garage…blue nitrale works good. If you wear glasses like I do, wear a full-face respirator.
I was quite surprised at the results so far, no runs or sags, nice even coat & not much of an over spray cloud.
gfadvm
#11 posted 07-15-2011 04:44 AM
Rod – I set my gun up about like you did: 50 psi but have never thinned my Min Wax spar at all. I put my projects on a shop made turntable. That way I can stand in 1 spot and spray with a big fan about 20’ behind me while I rotate the project. This really keeps the spray off me and out of my shop.
slick1
#12 posted 07-15-2011 06:16 AM
I tried spraying just un-thinned spar varnish with this gun, but it just came out in spurts & gobs. Using Old Masters Spar Varnish (satin).
I have converted an old 12’x 14’ polycarbonate paneled greenhouse as a paint spraying booth. Added two large filtered box fans, one for air in, one for air out, works great!
The turntable idea is great idea, no more untangling air hose from around my feet; but I would need a very large one to do adirondack chairs.
Uhmmm….I have a large old 3’ round wood wire spool out back…. Thinking….Thinking….need large lazy susan type Bearing Mechanism….uhmmmm..
gfadvm
#13 posted 07-16-2011 12:25 AM
Slick My gun either has a bigger orafice or Min Wax Spar is thinner than yours. My turntable is much simpler than you imagine. No bearings or engineering needed. I dont know how to post pics in blogs [even after Bentlyj tried to smarten me up]. If you’ll pm me with your e mail address I think I can send pics to you then you can put them on LJ if you want to.
gfadvm
#14 posted 07-16-2011 04:52 AM
Slick As you can see, this aint rocket science: a short piece of pipe welded to a disc blade. A piece of plywood with a hole in the center just larger than the pipe. A stack of drilled scraps beneath ply dictates how high off the floor the base is. I have sprayed a 6’ table by laying 2×4s across the ply to stand the table on. You can see the overhead door in the pic which I open when spraying. I think this could be done with ply and 1” dowel if disc blades, welding, etc arent possible in your case. PM me if you have questions. Bentlyj Thanks so much for posting this for me. I appreciate it. Someday, after I’m grown i’ll be able to do this for myself. LOL
