A quick question about handplane restoration
« back to Hand Tools forum
Forum topic by GregInMaryland posted 709 days ago 721 views 0 times favorited 11 replies Add to Favorites Watch
View GregInMaryland's profile
GregInMaryland
128 posts in 1194 days
709 days ago
Topic tags/keywords: handplane restoration
Hi
I am in the middle of restoring a Stanley number 3 and a number 4. Do most folks flatten the sole and then reapply the jappaning (paint) or paint and then flatten the sole?
Also, I have read that you should flatten the sole with the frog, blade, chipbreaker and cap installed. Is there any merit to this?
Thanks.
-- "I have found that hand tools are the best choice when I want to make mistakes at a slower rate of speed." Unknown
11 replies so far
View Arch_E's profile
Arch_E
47 posts in 718 days
#1 posted 709 days ago
As a user, I never repaint. If I wanted to paint, it would be the last thing done to the plane. Never paint areas where the frog sits, or the blade. And, you should definitely flatten the bottom with the blade, cap iron, and lever cap in place—but with the blade fully retracted.
14932 posts in 2415 days
#2 posted 709 days ago
Yes to flattening with everything assembled. I paint last, although I can’t think of a reason why you couldn’t paint first, flatten after.
View WayneC's profile
WayneC
9589 posts in 2294 days
#3 posted 709 days ago
Agree. Flatten frog and everything assembled. I am also not a fan of repainting/japanning planes…
View jamesicus's profile
jamesicus
106 posts in 888 days
#4 posted 708 days ago
I also do not re-paint antique tools. I occasionally touch up small paint chipped areas using a black magic marker for appearance sake.
James
View Bertha's profile (online now)
Bertha
12906 posts in 889 days
#5 posted 708 days ago
Agree with all above. Flatten the sole with the plane setup like it’s ready to cut, just with the blade withdrawn. That’ll make the theoretical flatness functional flatness. I paint planes, but I probably shouldn’t. All mine are users and sometimes I like them better reJapanned; sometimes not.
View Don W's profile (online now)
Don W
10208 posts in 764 days
#6 posted 708 days ago
If the plane’s are common 3 and 4, and the japanning is bad, I don’t see a problem painting. I typically paint first, but as charlie said, there’s not a reason behind it. I wouldn’t paint a type 1 or 2. I agree with flatten with everything together.
View Broglea's profile
Broglea
654 posts in 1287 days
#7 posted 708 days ago
You can paint before or after. Its up to your preferance. I’ve done both. It all depends. I agree with everyone else. Flatten fully assembled with blade retracted.
View David Grimes's profile
David Grimes
2065 posts in 836 days
#8 posted 708 days ago
Timely advice and all agree, too. Great question.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
GregInMaryland
#9 posted 707 days ago
Thanks guys.
I would say that there was less than 40% of the japanning left after the electrolysis bath, so I decided to take it all off and paint it hot pink. It takes a strong man to paint his tool hot pink.
These are intended to be worker bees in my shop and restoration teaching aids, so I wanted to break them down completely and start all over.
Cheers
David Grimes
#10 posted 707 days ago
So who did you get to paint it, then… lol j/k I’m just sayin’
I was thinking that more of a khaki / mauve camo might inspire a more manly motiff… ;=)
View HorizontalMike's profile (online now)
HorizontalMike
5586 posts in 1110 days
#11 posted 707 days ago
Blue painter’s tape and a razor blade are great for masking off areas NOT to be painted, as listed above. FWIW, I peel the tape after spraying but BEFORE it dries.
