Examples of resin glue and where to buy, please
Forum topic by Neophyte posted 07-22-2018 07:43 PM 474 views 0 times favorited 19 replies Add to Favorites Watch
View Neophyte's profile
Neophyte
32 posts in 2437 days
07-22-2018 07:43 PM
Topic tags/keywords: glue resin glue glue for plywood
Friends,
I recently posted a question in another forum regarding glueing plywood to plywood and a consistent recommendation was to use resin (or plastic resin) glue. I looked this up but need help figuring out which glue to buy and where – preferably locally available even at the orange or blue big box stores.
Are Liquid Nails and Dynagrip such products?
Thanks in advance
Marc
-- Marc, NY
19 replies so far
View ArtMann's profile
ArtMann
1006 posts in 896 days
#1 posted 07-22-2018 07:53 PM
No, construction adhesive is not plastic resin glue. Do a Google search for the unlikely topic of “plastic resin glue” and you will find the information you need.
View John Smith's profile (online now)
John Smith
1233 posts in 243 days
#2 posted 07-22-2018 07:55 PM
this product contains ZERO formaldehyde – that is where the health concerns
came from. the old two part resorcinol glue that caused many health issues
is not made any longer in the USA .
I called the DAP technical rep last month about the formaldehyde issue and the
guy said that NONE of DAP products contain formaldehyde – at all.
so I know this to be a true and verified fact.
there is also another Resin Glue called CASCAMITE that is used in boat building. A little more difficult to find.
one is for smooth joints, non-gap filling and another type is for rough joints that is gap filling.
-- Graduated Valedictorian from the University of HardKnocks --
View RobHannon's profile
RobHannon
138 posts in 611 days
#3 posted 07-22-2018 07:59 PM
They are probably recommending something like DAP Weldwood. Comes in a powder and you mix it when you are ready to use it. Long open time and very still so it is great for bent laminations. Never seen it in a box store though.
Liquid Nails and Dynagrip are construction adhesives, generally polyurethane based. They would certainly work for gluing plywood to plywood, but I don’t know why they would be any benefit to them over regular PVA wood glue. If you are just doubling up plywood for a bench top or something I am not sure there would be a huge benefit to something like Weldwood either. What are you building?
View wuddoc's profile
wuddoc
296 posts in 3798 days
#4 posted 07-22-2018 08:03 PM
Here is a website with info on plastic resin glue. I would warn my former students of safety concerns in handling the material. This involved ventilation, respirator and skin contact issues.
https://www.christinedemerchant.com/adhesive-glue-urea-formaldehyde.html
-- Wuddoc
Neophyte
#5 posted 07-22-2018 08:17 PM
Liquid Nails and Dynagrip are construction adhesives, generally polyurethane based. They would certainly work for gluing plywood to plywood, but I don t know why they would be any benefit to them over regular PVA wood glue. If you are just doubling up plywood for a bench top or something I am not sure there would be a huge benefit to something like Weldwood either. What are you building?
- RobHannon
I am building table tops for bistro tables. My question referred to plywood warping and several people suggested using non-water based glues. Here is my earlier post:
http://lumberjocks.com/topics/282226
-- Marc, NY
View Aj2's profile
Aj2
1577 posts in 1878 days
#6 posted 07-22-2018 08:37 PM
Wuddoc has given you good advise. It pretty toxic stuff.
I stopped using it because the glue lines are very hard
I think it will work if you can follow all the advice given.
Such as even glue spread flat clamping surface.
-- Aj
View jbay's profile
jbay
2487 posts in 979 days
#7 posted 07-22-2018 10:10 PM
Unibond 800 is good
Dap Weldwood is Ok
But just to put my 2 cents in, Titebond II is all you need. (Apply it with a roller.)
No matter what you use, it will need to be clamped to a flat surface in order to be flat.
How did you clamp the first one you made that warped?
View Tony_S's profile
Tony_S
896 posts in 3163 days
#8 posted 07-22-2018 10:41 PM
- jbay
Another 2 cents.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View BurlyBob's profile
BurlyBob
5816 posts in 2346 days
#9 posted 07-23-2018 12:24 AM
That Weldwood is amazingly strong glue. Probably as strong as anything out there. They recommend mixing it with cold water, in my experience luke warm is much easier.
View Woodknack's profile
Woodknack
12215 posts in 2460 days
#10 posted 07-23-2018 01:46 AM
Ask the guys making the recommendation. No second guessing that way.
Neophyte
#11 posted 07-23-2018 03:42 PM
Unibond 800 is good
Dap Weldwood is Ok
- jbay
There were two pieces roughly 4’ x 2’, one 3/4” thick and the other 1/2”. Used regular wood glue, clamped the margins all around and used screws for the center. Trimmed to size on table saw, got two table tops.
You also gave a very thoughtful answer to my original question in a different forum. In addition to the problems identified so far (unequal plywood thickness, perhaps excessive glue) I want to add that I did not use a flat surface for reference as the glue dried. I had them dry on top of some 2×4 to allow room for the clamps. I also wonder if the pieces need to be smaller when glued as evidently with the 4’ x 2’ pieces there is a large center area that is only “clamped” by screws
Thanks
Marc
-- Marc, NY
John Smith
#12 posted 07-23-2018 04:33 PM
Marc – to reiterate again, I personally feel that when two or more panels are glued
together, and clamps are applied all the way around the edges, it forces any excess glue
to the center of the panels, “possibly” creating a larger wet glue mass that “could”
result in more moisture in the center than the outside edges where the clamps are.
for a trial assembly – put two drywall screws in the center to prevent slippage, put on a flat floor,
and stack a lot of weight evenly on the panels and see how that works for you. (skip the clamps).
this would be for any liquid adhesive or epoxy. not contact cement or construction adhesive.
discussing the adhesive factors over and over is just arguing semantics.
wishing you the best of success in finding what works best for you.
Neophyte
#13 posted 07-23-2018 04:52 PM
- John Smith
Thanks for your feedback and I appreciate that you have followed these two threads.
I think the point that glue in the center of the boards dries slower is very important
Since your initial recommendation I have been looking for ways to build them that way
I still need to decide on the right materials for this project whether it will be all plywood or a combination MDF + plywood. I understand now to use same thickness material
Marc
-- Marc, NY
View jbay's profile
jbay
#14 posted 07-23-2018 07:02 PM
Your wayyy over thinking this.
Cut them to 2×2 before putting together.
Apply the glue with a roller, Clamp the things together, there is going to be no mass that collects in the middle.
Don’t worry about what speed the glue in the middle dries at, just clamp them and leave them over night.
The only other thing I would do would be to add some screws to the middle area before clamping. The screws will clamp the center and keep the tops from sliding around.
I would clamp 4 or 5 at a time…..
(ON A FLAT SURFACE) lol
That’s all I have to say, I’m out!
Good Luck
View OSU55's profile
OSU55
1781 posts in 2070 days
#15 posted 07-23-2018 07:37 PM
Clamping cauls will put even pressure across the surface
