What could I build with this motor.....?...
Forum topic by dakremer posted 07-10-2011 12:13 AM 6916 views 0 times favorited 12 replies Add to Favorites Watch
View dakremer's profile
2662 posts in 3020 days
07-10-2011 12:13 AM
hey guys. This is a blender motor. Someone threw the blender away because the pitcher was busted and so were the blades. The motor was still working just fine though so I swiped it.
Any ideas of what I could build with this (woodworking related)? Its 120V/60Hz
Is there any way to change the speeds of those buttons???
-- Hey you dang woodchucks, quit chucking my wood!!!!
12 replies so far
View Tedstor's profile
1643 posts in 2561 days
#1 posted 07-10-2011 12:19 AM
A small buffer?? Paint mixer?
#2 posted 07-10-2011 12:37 AM
hmm…dont need a paint mixer. Possibly a buffer though…...
View Mike's profile
406 posts in 2616 days
#3 posted 07-10-2011 02:07 AM
how about making some blades and making it into a variable speed wooden fan?
-- look Ma! I still got all eleven of my fingers! - -
View cranesgonewild's profile
344 posts in 2837 days
#4 posted 07-10-2011 02:59 AM
Seeing that you’re into chiropractics, you can make a beaded seat cover or something along those lines out of beads (scrap wood) you made yourself. The motor could be used to make your own bead sander. Similar to what Filinvested has done here.
-- I'm a Fungi --
View Jim Jakosh's profile
Jim Jakosh
20162 posts in 3034 days
#5 posted 07-10-2011 11:17 AM
If you could adapt a collet holder to it, you could make a small router table for 1/4” cutters for light work.
View David Grimes's profile
David Grimes
2078 posts in 2568 days
#6 posted 07-10-2011 11:34 AM
Put a cable drive shaft andf little chuck on it (like a Dremel). It might be a little bada$$.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Bluepine38's profile
3379 posts in 3014 days
#7 posted 07-10-2011 05:21 PM
If those buttons activate a sliding rheoostat, you could possibly change the speeds, but you have to take
it apart to find out, and then you have to get it back together. Might be easier to buy one of the router
speed control switches and use it. You could rig up some pulleys, gears, whatever and use it to power
one of those complicated marble machines, after you spent a month or two building the marble machine.
View teejk's profile
1215 posts in 2613 days
#8 posted 07-10-2011 05:34 PM
why do I sense a little german or swiss blood here (my grandpa used to make birdhouses solely to get away from my grandma and saved all the round hole cut-outs…my dad had cans full of bent nails)?
anyway you have already found several uses for it…something to collect dust, something to trip over, something to move around your workshop…you could try it for a clock (the different speeds would allow you to reset it to the correct time after checking your watch).
all kidding aside, the only thing I can think of would be some type of motorized toy
View KayBee's profile
1083 posts in 3175 days
#9 posted 07-11-2011 03:37 AM
Make a worksharp, scary sharp sharpener out of it. Put a platen for sandpaper on the arbor. Make a platform for running your favorite sharpening jig on, and sharpen away. You can still use the buttons to control speed. Crush speed sharpening : )
-- Karen - a little bit of stupid goes a long way
View thejaz's profile
40 posts in 2412 days
#10 posted 08-10-2011 01:25 AM
Make a panagraph machine for your engraving projects.
-- Tom Snyder - theJaz
#11 posted 08-10-2011 05:57 AM
panagraph? hmm… I’ll have to look that up
View Lee Barker's profile
Lee Barker
2170 posts in 2779 days
#12 posted 08-10-2011 06:21 AM
At last, a negative answer to the question, “Will it Blend?”.
For more information, search “will it blend” on YouTube.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
