Front door
Forum topic by richgreer posted 07-09-2011 03:53 PM 1217 views 0 times favorited 8 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3043 days
07-09-2011 03:53 PM
All the woodwork in our house is cherry (cabinets, crown molding, doors, etc.). There is one exception – the front door is white oak. The reason is obvious. The outside of the front door is exposed to weather and cherry does not hold up well to weather.
I’m considering making a door that is white oak on the outside and cherry on the inside. I would do this by gluing up rails, stiles and panels with oak and cherry. I’ve never seen this or heard of it being done, but it seems doable.
There is a lot of experience and wisdom on this board. Has anyone ever heard of this and/or seen one? Does anyone have any thoughts on potential problems with this approach (other than it will be a lot of work)?
Thanks in advance for the excellent advice I know I will get.
8 replies so far
View sras's profile
sras
4791 posts in 3098 days
#1 posted 07-09-2011 04:06 PM
Hi Rich,
I have seen a magazine article (but I can’t remember where) that use two layers of wood for the panels of an exterior door.
One thing I remember from that article is that the inner and outer panel were not glued together. That way the outer panel could respond to moisture changes from the outside and the inner panel would be independent.
I have no idea if it is an effective solution, but it sounds good.
We make things out of contrasting woods all the time, so I would think the rails and stiles could be made form oak/cherry and work out fine.
Sounds like it would be a beautiful door!
View Les 's profile
Les
201 posts in 2659 days
#2 posted 07-09-2011 04:10 PM
Rich,
It sounds like a great project and I started thinking about how to do it as soon as I saw it. The only problem I can see right might, I say might be the two woods movement. Temperatures will be quite different on each side. Check out this link and see what you think. Good luck with it, keep us informed.
http://www.woodworkdetails.com/Knowledge/Wood/Movement.aspx
Les
-- Stay busy....Stay young
richgreer
#3 posted 07-09-2011 04:21 PM
My theory (and I could be wrong) is that the movement of oak and cherry are not much different and if I align the grain so that it is consistent across the glue line a glued up board would act like a single board.
I’d probably use quarter sawn oak to reduce movement and minimize the chances for cupping or warping.
27250 posts in 3791 days
#4 posted 07-09-2011 04:28 PM
Rich, Rhett has posted an exterior door that he built with cherry and walnut. You might want to drop him a pm and see if he had any issues with his door.
View tdv's profile
tdv
1188 posts in 3039 days
#5 posted 07-09-2011 04:30 PM
I’m sure as long as the panels are floating (sorry if that is stating the obvious) there won’t be a problem cherry & oak will expand & contract at different rates due to density. the thing I would recommend is to make up each face of the panel ,mould the bevels on each outer face then don’t completely glue the faces just run a centre line of glue this will alloweach wood type to come & go the outer edges will be trapped it the rebate behind the moulded bead. It does work well I did once try gluing a two faced panel & one side expanded more & split the other
Good luck
Trevor
-- God created wood that we may create. Trevor East Yorkshire UK
View Moron's profile
Moron
5032 posts in 3862 days
#6 posted 07-09-2011 04:31 PM
Seen it done many times, just glue the byjeshus out of the two doors when laminating together….....actually makes for a very solid door and it resists warpage/twisting compared to a single door
View Mario's profile
Mario
171 posts in 3365 days
#7 posted 07-09-2011 04:31 PM
Try using 1/4 in cherry veneer on the back and build the rest of the door from quatersawn white oak. The veneer will minimize expansion and contraction differences and will ride along with the oak movement a lot easier.
View sras's profile
sras
#8 posted 07-09-2011 04:58 PM
Found the article I was thinking of – it’s from Woodsmith Issue #94. Looks like a good design.
