old craftsman belt sander
Forum topic by piesafejim posted 685 days ago 1911 views 0 times favorited 10 replies Add to Favorites Watch
View piesafejim's profile
piesafejim
33 posts in 703 days
685 days ago
Hello fellow LJ’s, I ent to an estate sale yesterday that had a ton of woodworking machines yesterda and came across this old cast iron Craftsman belt sander.
The sander not only has a belt but it also has a 9” disc, there were alot of sanding discs with it, they are not adhesive backed and i was wondering how they stuck those in the day. Any ideas would be helpful. I was ging to post a pic of it but i am not sure of how to do that in the forum. T
10 replies so far
View CharlieM1958's profile (online now)
14865 posts in 2390 days
#1 posted 685 days ago
I seem to recall that some of the old disc sanders used a heat-activated adhesive stick. You would turn on the machine, press the stick against the rotating plate to get some adhesive on it, then turn off the machine and apply the disc.
I don’t know if that stuff is still made. Maybe a spray adhesive would work.
piesafejim
#2 posted 685 days ago
That is probably what i will do i also thought about trying to find some self adhesive pads but i hate to waste the nes that came with it and they are much thicker and heavier than what we see today.
View Bill White's profile
Bill White
2608 posts in 2132 days
#3 posted 685 days ago
Spray adhesive, and you’ll enjoy the job of changing the disks (wink, wink).
Bill
-- bill@magraphics.us
View HalDougherty's profile
HalDougherty
1820 posts in 1408 days
#4 posted 685 days ago
Does your sander look anything like this one?
Just click the button above the reply box, then find the picture on your computer and hit the upload button. It will put your photo in your post. There is a preview button also to make sure you put in the photo you intended.
-- Hal, Tennessee http://www.first285.com
piesafejim
#5 posted 685 days ago
Thanks Hal,
Yep that looks like it lol. Thing runs like you just took it out of the box. I am guessing it may have come with a different frame at one time. This fellow had retrofitted alot of his machines but i tell ya they were selling some of his work there yesterday and i have to say it was good work
View Grandpa's profile
Grandpa
2381 posts in 847 days
#6 posted 684 days ago
I remember it just like charles described. The adhesive came in a tube that was about 1.5 inches in diameter. You turned the disc on and usually started int he center and rubbed it to the outside. Then you took the sading disc and applied it over the fresh adhesive. it was done. We cleaned them with a clean scrap board and rubbed the disc the same way…then applied new adhesive.
View NormG's profile
NormG
2580 posts in 1175 days
#7 posted 684 days ago
My father had the very same machine, I used it a lot myself. I remember the tubes, you peeled the wrap off it as you used it
-- Norman
View 000's profile
000
3352 posts in 788 days
#8 posted 684 days ago
I have an older Crapsman 6*48” belt / disk. I picked it up for $40.00 it needed bearings on both rollers and one new roller because the bearing mounts were shot.
It had those god awful cam type adjusters that simply do not work – ever – at all – under even the most favorable circumstances.
I tossed ‘em and replaced ‘em with direct screw adjusters with locking jam nuts that I made in the shop from aluminum scrap and bolts.
-- When the moderator chooses sides, his site sucks.
View Erdaram's profile
Erdaram
2 posts in 395 days
#9 posted 395 days ago
Hi Guys, I need a hand with this same model sander. Mine is a Craftsman 113.12193. Can any of you explain in detail how to get the disk or the guard off so that the belt can be changed?
Thanks, Eric
View nick85's profile
nick85
39 posts in 418 days
#10 posted 395 days ago
113.12193 is the part # of the motor, is there another number somewhere on the body of the sander, possibly under the bed?
I would imagine it would be similar to a bench grinder, in that you spin the disc while holding the shaft in place. Judging by the arrow on your machine, I would try hold the motor shaft and spinning the disc counter-clockwise. The shroud screws should be behind the disc, accessible once it’s out of the way.
-- "I suggest a new strategy, R2: let the Wookiee win."
