jigs
Forum topic by Partridge posted 03-31-2008 09:47 PM 1045 views 0 times favorited 9 replies Add to Favorites Watch
View Partridge's profile
Partridge
296 posts in 3863 days
03-31-2008 09:47 PM
Topic tags/keywords: jig
I am working on a TS sled and attachments. Almost done I will post when done.
Question is how do i finish? or do I.
I is just a jig! on the other hand we do put pride into all that we make right!!!!!!
-- I get out in the shop when I can
9 replies so far
27251 posts in 3729 days
#1 posted 04-01-2008 12:23 AM
I have started finishing my jigs with wipe on poly. It is an extra step but it helps protect and seal the plywood. It also makes it slide easier.
View juniorjock's profile
juniorjock
1930 posts in 3672 days
#2 posted 04-01-2008 03:01 AM
I try to put a finish on all my jigs just to try to keep the moisture out of them.
23563 posts in 3758 days
#3 posted 04-01-2008 09:43 AM
I don’t bother as long as the jig works thats all I need.
View Thos. Angle's profile
Thos. Angle
4445 posts in 3869 days
#4 posted 04-01-2008 01:39 PM
do or don’t, up to you
View GaryK's profile
GaryK
10262 posts in 3895 days
#5 posted 04-01-2008 04:26 PM
I never do.
View SteveKorz's profile
SteveKorz
2134 posts in 3621 days
#6 posted 04-01-2008 04:38 PM
I don’t finish it unless it’s something that I’m going to use a LOT or it was complicated to build, and I don’t want moisture screwing it up. Even then, I keep it simple.
View sIKE's profile
sIKE
1271 posts in 3661 days
#7 posted 04-01-2008 04:42 PM
Is it plywood? If so don’t worry, if hard wood, you might want to put some tung or danish oil on it….
View 8iowa's profile
8iowa
1569 posts in 3668 days
#8 posted 04-01-2008 04:56 PM
If you are using good plywood like Baltic Birch for your TS sled, finish is not necessary. However, It would be a good idea to wax the miter slot runners with Johnson’s paste wax.
Partridge
#9 posted 04-01-2008 05:26 PM
Thankyou for your comments
I think I will wipe some danish oil on fences, edges and bottom and then wax bottom. the deck is hard board and I think it will be all right besides it is replaceable.
