Guide bushing setup problem
Forum topic by willhime posted 07-21-2018 03:31 AM 310 views 0 times favorited 3 replies Add to Favorites Watch
View willhime's profile
willhime
127 posts in 1777 days
07-21-2018 03:31 AM
Topic tags/keywords: jig question resource tip trick router
I have a makita RP2301FC router and ordered this guide bushing set off amazon. I can’t seem to figure out how the guide base stays fixed into the router. I found the little metal tab thing that slide under the base plate and looks like it was meant to hold a guide plate in but nothing stops the slide from, well, sliding out. Am I missing a part like a different base plate I need to get or just not seeing something ? There’s 2 tapped holes on either side of the guide plate but the screw heads wouldn’t have the reach to hold down the plate, and if I put washers on there I’d have to grind them to a weird oblong shape which I’m not opposed to doing but since it’s not factory I’m wondering if they would just loosen and the. The plate goes flying off. Am I missing something here ?
-- Burn your fire for no witness
3 replies so far
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#1 posted 07-21-2018 04:04 AM
Looks like you are missing two compression springs that hold the sliding lever in place (P/N233105-3) ... did they go missing when you took off the base plate?
Part #88 in the parts diagram:
View gmc's profile
gmc
59 posts in 2395 days
#2 posted 07-21-2018 11:54 AM
+1 that is the part you need.
-- Gary, Central Illinois
willhime
#3 posted 07-21-2018 03:16 PM
Awesome. Thank you. Luckily one of the only times it pays to be a shop hoarder- I had 2 springs that exact size and they work.
