Attaching strips of wood to Formica counter
Forum topic by Will Merrit posted 07-21-2018 12:36 AM 356 views 0 times favorited 5 replies Add to Favorites Watch
View Will Merrit's profile
Will Merrit
87 posts in 1130 days
07-21-2018 12:36 AM
Hey everyone,
I have a project for my wife that involves covering our 1980’s Formica countertop with 1/4” thick strips of walnut. I am not sure how I can attach it though. I have thought about putting contact cement down and then trying to pin nail the strips down. There is obviously no easy way to hold them in place, the strips are about 1” wide and 1/4” thick, some have a little bow or cup in them that would easily come out if nailed down.
Thoughts?
5 replies so far
View JCamp's profile
JCamp
893 posts in 787 days
#1 posted 07-21-2018 12:52 AM
I’ve never done anything like that but my best guess is gonna b some sort of epoxy. At work we had a counter top coming unglued so we epoxied it and it’s stayed down. No issues for over two years
Your mind is probably already made up but I don’t think I’d try this, at least not as a long term solution. It’s my thoughts that long term I won’t hold up to the water and heat that most counters are exposed to.
I’ve seen ppl paint counter tops for a cheap redo. Myself I’ve installed tile and it has turned out nice and is much cheaper than anything you’ll find that’s normally store bought
-- Whatsoever thy hand findeth to do, do it with all thy might
View ArtMann's profile
ArtMann
1216 posts in 1053 days
#2 posted 07-21-2018 01:34 AM
I agree with JCamp. In the end, you will not b pleased with the results, no matter what adhesive you use. You will have the best chance of success using epoxy. Contact cement will not require any fasteners. That is why they call it contact cement. It will not provide the durability of epoxy and the pieces can’t be adjusted if you make a placement mistake.
View bilyo's profile
bilyo
473 posts in 1339 days
#3 posted 07-21-2018 02:12 PM
I tend to agree with the above comments in that I don’t think that what you propose doing is a good idea. Having said that, a number of years ago I glued new formica down to old using the usual solvent based contact cement. I just thoroughly sanded the surface of the old before applying the new. It worked just fine and held up for many years. I see no reason why it wouldn’t work for your project.
My concern is more about using walnut (or most any wood) for a kitchen counter top. IMO it is just not an appropriate use. Perhaps if you provided more information on what you are doing and why, we could be more helpful and supportive.
View Fresch's profile
Fresch
369 posts in 2157 days
#4 posted 07-21-2018 02:46 PM
?sand glue & screw Luan then glue your strips then pour the clear epoxy (bar counter top style) on.
What about the back and side splash?
Rip off old counter top start new.
View bondogaposis's profile
bondogaposis
5150 posts in 2588 days
#5 posted 07-21-2018 03:02 PM
Bad idea, the counter is stable, but the wood strips are not, they will move with every change in humidity. In the end gaps will develop between the boards and/or they will break free from the counter top. The best solution is to replace the counter top.
-- Bondo Gaposis
